Home > Puma (Tdci) > Light switches: where can I buy these online?
Naks
Hi all
I need a couple of these switches, anyone know where I can find them online?
thanks!
Post #31579 6th May 2010 9:40am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Try TLO in the disco3 site, they look like disco2 spotlight switches Original Member Pie n Pea Club.
110 HCPU Tipper
Post #31583 6th May 2010 10:08am
dgardel
Italy
Re: Light switches: where can I buy these online?
LR Part YUG000540LNF (cost is + or - 7.20£, 8,50€) same form factor for Puma Defender (I installed it on mine)
or here on-line BRIT-CAR.CO.UK
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31589 6th May 2010 11:29am
Naks
Thanks man, did you also need a separate connector? Someone else said I need this connector: http://shop.dingocroft.co.uk/acatalog/Elec...#aZZPLUG01
Post #31594 6th May 2010 11:51am
dgardel
Italy
yes correct!!!
I bought it from Dingocroft also!!!! Mr. Green Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31595 6th May 2010 11:54am
Eduardo
I Bought those in http://www.rimmerbros.co.uk/ at 7.06 GBP (VAT Incl) + Shipping cost
http://www.rimmerbros.co.uk/Item--i-YUG000540LNF
Delivery time due the volcano was a little bit too long but no their fault
No complains at all
Cheers Eduardo
Post #31598 6th May 2010 12:33pm
Naks
dgardel wrote:
yes correct!!!
n00b question, but what does the connector do? And why can't you use the switch on its own? Question
Post #31600 6th May 2010 12:38pm
dgardel
Italy
Naks wrote:
dgardel wrote:
yes correct!!!
I suppose that you'll build the wiring loom for the front foglight.....
The defender haven't fog light wiring predisposition so how you can connect electrically the switch to the wires? by the right connector....
the fogswitch pinout is (YUG000540LNF):
1 = earth switched
2 = +vehicle illumination ("on" with sidelights)
3 = earth (ground)
4 =
5 = + control light (small orange led, feed from powered device)
see HERE for general infos
and DOWNLOAD ME for LR Driving Lamp Installation instructions Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31605 6th May 2010 1:58pm
