![]() | Home > Td5 > Speedo bulb change |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 ![]() ![]() ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
The bulbs are sunk into the speedo, If you get a long pair of decent tweezers you can grip the flat sides of the bulb and twist them to remove the bulbs. You should then see some contacts on the holder.
Have a shuffties at the link above for more info. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Roy l Member Since: 01 Aug 2013 Location: Surrey Posts: 9 ![]() ![]() ![]() |
Thank you very much for clearing this up.
Peter Member Since: 04 Mar 2012 Location: Kent Posts: 153 ![]() ![]() ![]() |
If you have not got tweezers these are cheap and much stronger and work perfectly
Ebay item eBay Item No. 271175281787 Cheers Peter. |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
I attacked an old pair of long nosed pliers with a grinder in order to reduce them in size to something small enough to fit
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
Those mini long nose pliers look a great idea.
I did this job earlier in the week and it's a bloody fiddly job even with tweezers. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
Had bought another Def TD5 speedo cluster a few years back ( was going to put on'87 90) have a spare to play with. Takes about 10 seconds to change one of the bulbs after a trial run.
Am now awaiting new SMD LED's hope they fit eBay eBay Item No. 161034467304. As its so easy to fit might get some red ones for winter driving, or a set for spare speedo. Can't believe I don't read my old posts... http://www.defender2.net/forum/topic12373.html Socket seems sensible! Peter Kent LRC. |
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 ![]() ![]() ![]() |
I have just replaced the works td5 bulbs myself with some lovely blue led bulbs
a bit sad but I quite lke them |
