Home > Tdi > 200 TDis - what to look out for when buying?
BigWheels
While good 300TDis seem to be like gold dust, there are 200 TDis for sale around at lower/more affordable prices.
I am looking for a 110 hard top or estate. I would fit a Red Booster clutch servo as its first mod.
What should I look out for especially when checking 200s? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #314759 9th Mar 2014 7:22pm
shaggydog
Lots are advertised as "Genuine 200tdi!!" but have actually been fitted with a discovery engine. They are very different to look at so should be obvious, also if the seller doesn't want to open the bonnet walk away as could mean there are other nasties to be observed.
Rust is a general problem, they are getting on for 22 years old now so most have been patched or desperately need it, Check Bulkhead, Doors, A and B posts, Rear Cross member.
As Salisbury axles are bullet proof but can suffer from leaks, a nose leak can be a expensive and difficult problem to solve but isn't the end of the world.
There are very few in original condition and most will have had some kind of mod in the past by now, so try and get one which is as original as possible as it will give you the best starting point and less likely to inherit someone else's muck ups.
Post #314857 9th Mar 2014 10:13pm
GUM97
^^Completely agree with the above. I'm not a huge fan of the 200, (hence why I've got a 300), but watch out for nasty Disco transplants, and most importantly rust! An engine to TDi for!
Post #315027 10th Mar 2014 7:04pm
g-mack
red booster servo looks good but i wouldnt be shelling out nearly £400 for a nice light clutch! it only takes a day or so to get used to the normal one in my opinion ! i suppose if swmbo wanted to drive it Big Cry it would be worthwile.
im guessing though you will find plenty of other things to spend on it first! Thumbs Up My 109 thread
my youtube channel
Post #315032 10th Mar 2014 7:16pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Can you do the Td5 "clutch pedal mod" to a 200 Tdi ? My old 300 Tdi certainly had it. 2005 Td5 90 XS
Steve
Post #315040 10th Mar 2014 7:28pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Purely for interest, how heavy is the clutch on a 200 Tdi? Question
Is it somewhere between a more modern Defender and a Series vehicle, or tougher again than what I am now used to on my S2A? 1970 Series 2A 88"
Post #315054 10th Mar 2014 7:59pm
RobKeay
200 is a great engine they are pretty bulletproof. 300 had the timing belt issues. Biggest problem with 200tdi is the gearbox.
I've been rebuilding one for a few years and they are so easy and forgiving to work on. I haven't got a clue about engines and with some help to finish it. It runs really well.
The problem with the one I am rebuilding everything was rotten. To get it going it's be put back together with mainly td5 parts. There are a few good ones out there.
Post #315062 10th Mar 2014 8:15pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Its a lot lighter than a series vehicle and if you are used to a series you won't have a problem, i don't understand why peeps say a defender clutch is heavyer they obviously havn't driven a series before Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #315067 10th Mar 2014 8:24pm
Lou Sparts
I once owned a 2.5Td 90 (which uses same clutch and gearbox) and the clutch was VERY heavy and this resulted in the clutch arm being punched through on its pivot point which is not uncommon.When the clutch was eventually replaced it was so much lighter it was like a different car. 2005 Td5 90 XS
Steve
Post #315068 10th Mar 2014 8:26pm
shaggydog
I have a 200TDI which I run every day in a mix of fast A roads, B Roads, Town Traffic and Manoeuvring and don't think the clutch is too heavy.
Mine has a HD Clutch Kit and the army spec pedal so is quite heavy, but once you have done a few shunts and stop starts around town your leg builds muscle and it stops being a problem.
Plus your girlfriend knows where you are because you walk in circles, between Work, Pub, and Home.
For £400 I'd put it towards getting a better starting point.
Post #315069 10th Mar 2014 8:29pm
cornish rattler
That's why in the end I settled for a 200tdi as whilst I was saving for a 300tdi they was about £3,000-£4,000 then when I had the money saved they immediately went to £5,000 + which I just could not afford so on another forum I got offered this one a 2.5td converted to a defender 200tdi for £2,700 with minimal work needed Very Happy
 Graham
Post #315074 10th Mar 2014 8:33pm
RobKeay
It's surprising just how much lighter they have the pedal on a tdci. The 200 takes some getting used to but they are great to drive. One of the lads had a 200 tweaked it went quite well.
Post #315076 10th Mar 2014 8:37pm
