![]() | Home > Td5 > Warning lights :( go away |
The switch on the handbrake itself. Pull the rubber gaitor off and take the wire off the switch and put it back after a clean.
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
The switch might have come loose, or the handbrake needs very slight slackening. 1998 110 300Tdi White Hard Top
The handbrake switch could be at fault, but I think it also illuminates when there's a brake fluid problem. An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Millsy94 Member Since: 06 Jun 2013 Location: Gloucestershire Posts: 91 ![]() ![]() ![]() |
It's not the handbrake switch that's already unplugged
Brake fluid is very near the top of the reservoir but ill top her right up to rule that out cheers
If it's happened since the service I'd be looking at the fluid reservoir and associated wiring in the likelihood of it had been disturbed.
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
Mine was doing this, topped up the reservoir, hey presto - no flashing light. It wasn't me!
I have seen the float in the brake res get fluid in it so doesnt float anymore or only floats a bit and light comes on hitting bumps etc
may be worth checking |
If you suspect the brake res. just disconnect it, if you bridge the two wires, your warning light should come on. Pov.spec,ftw. 2006, 110,TD5.
Full marks!! Had a look this afternoon and yeah my float has taken on fluid, unplugged it to test and have seen the light since, many thanks my mind is at rest cheers for quick replies though guys |
that's good , always good to get result
