Home > Td5 > Warning lights :( go away
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
Hi all my td5 has developed a new issue, the stop light on the dash (the one that comes on with the handbrake) flickers and occasionally stays on, it happened the morning after she was serviced, no other issues, checked all fluids, what else cause cause this light to illuminate?? Could be chance but seems to happen more if I'm going down hill (with or without brakes) please help I'm worried and its my daily drive cheers Ed
Post #314764 9th Mar 2014 6:27pm
mk1collector
The switch on the handbrake itself. Pull the rubber gaitor off and take the wire off the switch and put it back after a clean.
Post #314765 9th Mar 2014 6:33pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
The switch might have come loose, or the handbrake needs very slight slackening. 1998 110 300Tdi White Hard Top
Post #314768 9th Mar 2014 6:33pm
GUM97
The handbrake switch could be at fault, but I think it also illuminates when there's a brake fluid problem. An engine to TDi for!
Post #314790 9th Mar 2014 7:21pm
Millsy94
It's not the handbrake switch that's already unplugged
Post #314808 9th Mar 2014 7:48pm
Millsy94
Brake fluid is very near the top of the reservoir but ill top her right up to rule that out cheers
Post #314843 9th Mar 2014 8:44pm
JWL
If it's happened since the service I'd be looking at the fluid reservoir and associated wiring in the likelihood of it had been disturbed.
Post #314889 9th Mar 2014 10:16pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Mine was doing this, topped up the reservoir, hey presto - no flashing light. It wasn't me!
Post #314892 9th Mar 2014 10:19pm
munch90
I have seen the float in the brake res get fluid in it so doesnt float anymore or only floats a bit and light comes on hitting bumps etc
may be worth checking
Post #314908 9th Mar 2014 11:13pm
jimbob7
If you suspect the brake res. just disconnect it, if you bridge the two wires, your warning light should come on. Pov.spec,ftw. 2006, 110,TD5.
Post #314956 10th Mar 2014 10:29am
Millsy94
Full marks!! Had a look this afternoon and yeah my float has taken on fluid, unplugged it to test and have seen the light since, many thanks my mind is at rest cheers for quick replies though guys
Post #315156 10th Mar 2014 10:27pm
munch90
that's good , always good to get result
Post #315158 10th Mar 2014 10:31pm
