Home > Td5 > Another snorkel / RAI query
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Through searching I see there are a lot of queries already on this topic however I had a few specific questions so apologies for another thread!
The Mantec plastic jobby seems to have issues with letting heavy spray in. Reported here and on other forums. I don't know if this same issue also affects the metal construction Mantec version?
The Safari snorkel appears to need the aerial repositioning on the front wing. Is this simply an inner wing position change or does this require a new hole to be drilled in the wing top?
Just trying to find the one with the least issues / hassle that can be effectively sealed!
Cheers!
Post #314264 7th Mar 2014 2:26pm
SailingTom
Only affects the 'plastic jobby' for some people but for most its ok. All the others seem fine for that issue.
I dont know where you heard that about the safari? Ive never heard of that before and mine fitted straight on without the aerial being anywhere near. The safari in my opinion is the best and has the advantage of sealing properly and is easy to fit.
Ive got a genuine land rover one for my puma (same as plastic jobby) but it isnt a snorkel only a raised air intake.
Hope this helps
Cheers Tom Thumbs Up (pic of genuine td5 safari snorkel on my old td5 with no issues)
 Defender puma dormobile camper
Post #314289 7th Mar 2014 4:02pm
Freypal
Cheers for the quick reply Tom!
Bit confused though as I'm not sure if Safari have changed the design. Some people refer to it sealing against the wing and others saying there is a moulded pipe that passes through the wing and does away with the plastic land rover air duct. Not sure if the new ones just seal against the wing?
If so the metal mantec seems the way to go as that seals against the wing but could be really tightened up!
Anyone know know if the Safari has changed? Confused
Post #314431 8th Mar 2014 8:30am
SailingTom
That was the current td5 one (still available now i believe) and came with the internal pipework aswell as instructions for other bits to seal to make water tight.
Cheers Thumbs Up Defender puma dormobile camper
Post #314960 10th Mar 2014 11:56am
Freypal
I don't suppose you know what part no that was?
Paddocks list a DA3069, elsewhere i see 580HF ?
cheers!
Post #315012 10th Mar 2014 5:29pm
SailingTom
Dont know to be honest
this is where i got it from my local garage
http://www.ebay.co.uk/itm/Land-Rover-Defen...335ba98816
Shows the parts clearly in the pic aswell Defender puma dormobile camper
Post #315015 10th Mar 2014 5:44pm
Ruari
2000 Defender 110 Td5 HT Alpine White
I took away my aerial and used a 12v booster aerial stuck to the windscreen. (it still doesn't help I get crap reception, think its electrical interference)
Where the aerial was I put in a rubber grommet and now my breather pipes come out the wing and up the side of the snorkel. Original aerial should still fit.
Post #316353 16th Mar 2014 11:09am
Freypal
Cheers for the info chaps!
Post #316922 18th Mar 2014 5:25pm
landy andy
I've fitted mantec plastic jobby and now a safari. Neither has caused the ariel to be repositioned. The mantec caused problems in high spray conditions that caused MAF failure, and air filter was so wet, water was running out of it. The safari is a better sealed unit, with a nice set of instuctions, and good set of seals, where the mantec requires lots of silicon sealer.
The 580HF is the newer version and the HF is for High Flow.
Andy
Post #316951 18th Mar 2014 7:23pm
Freypal
Cheers Andy,
interesting that some people seem to need to move their aerial! Was yours the standard fitment LR aerial?
and was it the 580HF you fitted to yours?
Post #316956 18th Mar 2014 7:36pm
landy andy
Yes and yes Thumbs Up
Post #316960 18th Mar 2014 7:38pm
Freypal
Awesome cheers mate!
Post #316962 18th Mar 2014 7:47pm
