Home > Technical > TD5 'Groans' in Reverse until warm
Page 2 of 2 <12
Laurie
Do you have the clutch fully engaged when reversing?
If only partly engaged it could just be the infamous TD5 clutch groan.
Post #313764 5th Mar 2014 4:18pm
Norm4n
This symptom sounds like my wife 😄
Post #313781 5th Mar 2014 6:01pm
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
Rolling with laughter
Post #313930 6th Mar 2014 11:13am
danridge
Hi Laurie - I engage reverse with clutch fully depressed then as I let it out and the start rolling backwards it starts to groan. It continues to groan until I select a forward gear (never tried anything other than 1st in high) and groaning stops as soon as I start moving forward
Post #313931 6th Mar 2014 11:15am
danridge
party monkey wrote:
@Dan... is it practical to reverse out in low box??
Better low speed control and so little/no need to slip the clutch and potentially create the groan... Just a thought Smile
Cheers Monkey Thumbs Up Worth a test but probably not practical in the long run
Post #313932 6th Mar 2014 11:17am
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
Td5 clutches only have an 'infamous clutch groan' if the spigot bush is noisy Thumbs Up
Post #314104 6th Mar 2014 9:43pm
danridge
Thanks Thumbs Up
Post #314166 7th Mar 2014 12:17am
Laurie
Mine's groaned as long as I've had it - from 6,700 miles.
Post #314167 7th Mar 2014 12:21am
Page 2 of 2 <12
