![]() | Home > Td5 > Down on power after fpr replacement |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Sounds like a split intercooler hose ! Would be a bit of a coincidence happening when you,ve changed the FPR but worth checking all the same. 2005 Td5 90 XS
Steve |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Cheers. I hadn't ruled out a huge coincidence as even bigger ones than this have happened to me before. For example, after a complete high pressure steam clean and full dinitrol treatment, carried out by myself, I immediately got the three amigos. I must have damaged the abs sensors surely? Plugged in to diagnostics...abs pump failure...the cause, a corroded terminal on the modulator relay under the drivers seat!!!
Is there any way I can tell by looking if it is the inter cooler hose? Will it deform/expand when the engine revs? Is it likely to be a split? |
Had a very similar thing in a mondeo at work recently hose had split enough to get a couple of fingers in,usually happens at a low point where oil collects and degrades the rubber. 2005 Td5 90 XS
Steve |
Thank you so much...I have found the problem, although it is not a coincidence as I am a complete clot.
In investigating whether or not it is possible to replace the fuel pipe to the regulator which runs along the side of the engine without taking the manifold off, I removed the inter cooler hose to the egr to get a closer look at the union on the pipe. In my haste to put it all back together I completely forgot to do up the jubilee clip on reassembly. Time for a quick test drive but I am 100% convinced you have just helped my cure the problem. M ![]() ![]() |
Problem solved,no cost,happy days
![]() Steve |
