Home > Puma (Tdci) > Have you ever come by.... |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
My Alfa Romeo would do that (sold it ages ago), lock it and it was always open when I got back. Turned out to be the alarm unit, it was sitting in a pool of water in the boot. I unplugged the alarm box and it'd stay shut but of course it'd have no alarm!
Given all the rain we've had, could it be water ingress somewhere? |
5th Mar 2014 7:43pm |
Mac22 Member Since: 22 Nov 2013 Location: Merseyside Posts: 675 |
Cheers....Just what I need more water...
5th Mar 2014 7:51pm |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 |
Was ahving this on my Puma until recently but with added alarm going off. Seems that the centarl locking actuator was faulty on passenger door. Was also advised by another member here that bad earth can cause this type of fault. Good Luck.
Steve |
5th Mar 2014 7:55pm |
AlisterC Member Since: 25 Apr 2012 Location: Somerset Posts: 116 |
I had exactly this problem on my Puma last year.
It was a faulty actuator. Sometimes it would unlock immediately, sometimes not for an hour or two. |
6th Mar 2014 7:30am |
timbar Member Since: 30 Jul 2013 Location: Milton Keynes Posts: 245 |
I've walked away from ours a few times pressing the lock button, only to come back to find it unlocked.
Now I stand in front of it, point the fob at it and mash the button til I hear it go clunk. Will pay more attention and see if it happens again ... 2009 110 XS Station Wagon |
6th Mar 2014 10:08am |
danridge Member Since: 28 May 2013 Location: Bath Posts: 438 |
I've found the same on my TD5 a couple of times but put it down to accidently kitting the unlock key whilst in pocket. Mine doesn't blip-blip on lock/unlock and it does take much pressure to push it.
That said one of the rear doors needs locking manually as the actuator has gone so could be related to that |
6th Mar 2014 11:23am |
I know someone who had a similar problem on a Range Rover, he would lock the vehicle and on his return the vehicle was unlocked and the indicators would be flashing, it only happened when he was at work .
He had all the electronic and actuators checked and eventualy changed when on two occasions the vehicle was totally immobilised and had to be returned to a dealership, but the problem persisted. He mentioned the problem to someone who lived near by his place of work and it turned out that a number of people had the same problem on varying vehicles but only when parked in certain locations. It was later found out to be a rouge Wi-Fi signal coming from a house near by that was causing the problems. He did tell me how they found out but I got lost 30 seconds into the explanation. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
6th Mar 2014 12:26pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5724 |
Had this on my Td5. Was the actuator in drivers door.
Andy |
6th Mar 2014 2:23pm |
Stayed locked last night and all day....After I hid the spares keys.
It could be a coincidence, then again.... |
6th Mar 2014 7:07pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1917 |
Off marque my new VW transporter has the function if you keep the unlock button down on the fob all the windows open!!! Came back a few times with the windows down, now I am paranoid it will happen again, in the rain 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
6th Mar 2014 7:22pm |
Mine used to be much worse in the cold.
Andy |
6th Mar 2014 7:51pm |
