Home > Off Topic > IP66 or above |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Tim at Mobile centre does one. It is rated at 16amp, but has 5 pins so you could double up and leave one pin redundant.
4th Mar 2014 9:27pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Nakatanenga a site sponsor does the Aquaseal 5 pin connector rated at 16 amp and IP65 at 34 euros.
We get regular supplies from Germany so could supply the Aquaseal connector for £30-£31 Might also be worth considering the Magcode power system but max current is 15 amp Brendan |
4th Mar 2014 10:16pm |
v8steve Member Since: 18 Apr 2011 Location: dumfries scotland Posts: 195 |
thanks for the quick replies.
talk about not being able to see the wood for the trees. will give tim a shout thanks steve 110 xs s/wagon s3 swb soft top |
5th Mar 2014 8:54pm |
Google 'Buccaneer 400 Seies IP Connectors' and take your pick.
http://www.ebay.co.uk/itm/3-PIN-400-SERIES...144wt_1197 http://www.ebay.co.uk/itm/Flange-mount-soc...1251wt_960 Or look here under connectors and scroll down to weatherproof..... http://www.vehicle-wiring-products.eu/VWP-...ectors.php If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
5th Mar 2014 9:03pm |
I have used Binder Connecters, IP67 rated:
Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
5th Mar 2014 9:59pm |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
The Binder connectors above are used on our cranes by Potain only waterproof after a lot of silicone honest !!! 90% of my crane breakdowns are due to water in plugs and sockets, harting sockets are even worse Bain of my life. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
5th Mar 2014 10:14pm |
Hmm, my car lives outside, and I have the Binder connector now for four years and never had any issue with it... Cheers, Vincent
6th Mar 2014 7:10am |
ordered on from mobile centre tonight,
thanks for the heads ups 110 xs s/wagon s3 swb soft top |
6th Mar 2014 9:22pm |
plug and socket arrived first thing today great service from mobile centre.
good quality product. the pictures on mobiles web site don't do it justice. well chuffed thanks again for the replies steve 110 xs s/wagon s3 swb soft top |
10th Mar 2014 10:24pm |
