Home > Off Topic > IP66 or above
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
IP66 or above
hello all and first thanks for looking.
my problem i want to solve is this i need a panel fit socket and plug IP66 or above.
this is to go on the roof of my defender for pluging my led light bar into.
now i have searched the web but can't find just what i'm lookinng for.
2 pin socket with srcew on cap (for when plug not fitted roof rack off)
2 pin screw fitting plug (for good connection as will be fitted for long periods)
socket to be neat and corrosion resistent (not 16/32amp industrial Whistle )
rated at 16mps or over.(this seems to be the problem part)
have looked at loads of marine stuff but no luck in this country.
don't mind paying for the right thing.
any links or solutions greatfully recieved and followed up.
thanks in advance steve Thumbs Up
p.s
light bar and rack on need to take off for some work. cable hole already in roof 20mm.(can ofcoarse/will make bigger for socket. 110 xs s/wagon
s3 swb soft top
Post #313591 4th Mar 2014 9:09pm
smb
Tim at Mobile centre does one. It is rated at 16amp, but has 5 pins so you could double up and leave one pin redundant.
Post #313599 4th Mar 2014 9:27pm
leeds
Nakatanenga a site sponsor does the Aquaseal 5 pin connector rated at 16 amp and IP65 at 34 euros.
We get regular supplies from Germany so could supply the Aquaseal connector for £30-£31
Might also be worth considering the Magcode power system but max current is 15 amp
Brendan
Post #313623 4th Mar 2014 10:16pm
v8steve
thanks for the quick replies.
talk about not being able to see the wood for the trees. Embarassed
will give tim a shout
thanks steve Bow down 110 xs s/wagon
s3 swb soft top
Post #313830 5th Mar 2014 8:54pm
K9F
Google 'Buccaneer 400 Seies IP Connectors' and take your pick. Thumbs Up
http://www.ebay.co.uk/itm/3-PIN-400-SERIES...144wt_1197
http://www.ebay.co.uk/itm/Flange-mount-soc...1251wt_960
Or look here under connectors and scroll down to weatherproof.....
http://www.vehicle-wiring-products.eu/VWP-...ectors.php If you go through life with your head in the sand....all people will see is an ar5e!!
Post #313832 5th Mar 2014 9:03pm
VeeTee
Netherlands
I have used Binder Connecters, IP67 rated:
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #313844 5th Mar 2014 9:59pm
noworries4x4
The Binder connectors above are used on our cranes by Potain only waterproof after a lot of silicone honest !!! 90% of my crane breakdowns are due to water in plugs and sockets, harting sockets are even worse Bain of my life. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #313846 5th Mar 2014 10:14pm
VeeTee
Netherlands
Hmm, my car lives outside, and I have the Binder connector now for four years and never had any issue with it... Cheers, Vincent
MySite
Post #313873 6th Mar 2014 7:10am
v8steve
ordered on from mobile centre tonight,
thanks for the heads ups Thumbs Up 110 xs s/wagon
s3 swb soft top
Post #314091 6th Mar 2014 9:22pm
v8steve
plug and socket arrived first thing today great service from mobile centre.
good quality product. the pictures on mobiles web site don't do it justice. Cool
well chuffed Bow down
thanks again for the replies steve 110 xs s/wagon
s3 swb soft top
Post #315154 10th Mar 2014 10:24pm
