![]() | Home > Puma (Tdci) > Wiper relay |
RustyM Member Since: 28 Oct 2013 Location: Africa/The Med Posts: 222 ![]() ![]() ![]() |
That's not bad for a new VAG relay, I paid £42 in the UK. And yes a great mod so many thanks to the guys on this forum who discovered which one to use
![]() 110 XS Previously owned SI SII SIIa SIII & Light weight (air portable) |
£1 is all I paid.
![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Indeed a good find, I however was not able to find one at any of the local scrap yards hence conceding and purchasing a new one.
I struck lucky I got a short 99 and a long 99 both at the same time. If you know where to look there are many different marques of vehicles and relays that will do the same job....A lot of people seemed to have cottoned on to this easy modification and admittedly most of the scrap VWs I looked round the relays had gone. Think mine came from a Saab if memory serves me correctly.
http://wiki.seloc.org/a/Wiper_Variable_intermittent If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
