Home > Puma (Tdci) > Supply & fit clutch price
Norm4n
What have you paid for this?
Or any traders wish to quote me?
Just planning ahead, 2008 tdci, it's not broke but does rattle a lot!!
Post #312147 27th Feb 2014 7:23pm
Dieselhead
Got to do mine also as rattles like hell
Got all the bits
Also got a mates one to do also, nearly on 100k so hes had his money out of that Shocked
Not sure what I will charge him yet Confused Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #312159 27th Feb 2014 7:42pm
Norm4n
Easy job or hard one?
Post #312165 27th Feb 2014 8:07pm
Not difficult, though the weight of the gearbox doesn't help. If you have a 4-post lift and a gearbox jack it is very straightforward.
Post #312214 27th Feb 2014 10:49pm
chrisbowler
It is a days work. Easy job if you split two gearboxes and take t box out first.
Chris bowler
Post #312215 27th Feb 2014 10:50pm
^^^ Which is especially worthwhile on a Puma since you can inspect the infamous adaptor shaft splined coupling.
Post #312219 27th Feb 2014 11:17pm
TJ101
As said,, not that hard, and much easier than a TD5
In one lump,, but worth splinting to check the shaft spline California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #312220 27th Feb 2014 11:19pm
Dieselhead
Do able in a day. As already done puma clutch on works 110 I know which bits to take off now Whistle
Got a landrover mate helping so extra pair of hands will help a great deal with these on your drive repairs Thumbs Up
Am able to borrow a transmission jack as cant get it up on a 4 post ramp.
The last puma had a gearbox fault so had to come right out. I guess you only need to pull it away from the engine enough to do the job & get it back asap Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #312240 28th Feb 2014 7:17am
MartinK
Here's an interesting thread...not a Puma, but probably fairly similar?
http://forums.lr4x4.com/index.php?showtopic=4380 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #312244 28th Feb 2014 7:56am
munch90
autodata repair times allow 4.1 hours r&i , so most garages will quote 4.5 hours labour ( or should !!! )
Post #312256 28th Feb 2014 8:22am
Norm4n
Thanks for the info
Post #312289 28th Feb 2014 10:18am
MartinK
I had the clutch replaced on a TD5, and it was just under £1000, but that also included a full service whilst it was in...so maybe £750-£800... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #312347 28th Feb 2014 2:01pm
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Had mine done by Rogers in Bedford, they picked it up and did it all for £650 inc VAT. 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #312355 28th Feb 2014 2:38pm
