Home > Td5 > Disconnecting the battery....
jools
United Kingdom 2003 Defender 90 Td5 XS CSW Zambezi Silver
How do I disconnect the battery without the alarm going off?
The manual says that I should:-
turn on the ignition, turn it off again... remove the key....and disconnect the battery within 15 seconds
and the sounder should not sound.....
..... but it does!!!
Tried various combinations of keys on/off - in/out without luck
Anyone got any ideas?
Jools 2003 90 XS SW
Support Devon & Cornwall 4x4 Response - www.buy.at/dc4x4
Post #31206 1st May 2010 7:53pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Hi Jools,
That is the correct way to disconnect the battery. You maybe need to move the key fob further away from the ignition barrel when you remove the key, thats all i can think of.
When i developed the Cruise kit that you are fitting i didnt disconnect the battery, i just put that in the instructions as a safety thing while working on the wiring. All the wires that you need to solder onto are ignition live only so there shouldnt be any current to them to cause any problems as long as the key is removed. Having said that its always best to be safe and i would never fit a kit to a customers car without disconnecting the battery first.
Pete.
Post #31208 1st May 2010 8:12pm
Zinke
Just thought of something else too, it says in the land rover manual to disconnect the negative first but in my instructions it says to disconnect the positive. I cant see how it makes any difference but it might be worth trying.
Pete.
Post #31209 1st May 2010 8:18pm
jools
Thanks Pete
yes it is the negative I was removing.....
I was standing outside on the passenger side - so removing the key right outside and it still didn't make any difference
I took the same approach - after trying for about 15 minutes to disconnect the battery in silence I decided that it would have to stay connected rather than annoy the neighbors any more!!
I was getting on fine before it started to rain!!
Jools 2003 90 XS SW
Post #31224 1st May 2010 11:05pm
markb110
Hello All
Dont know if this will help but i had the same issue.
i am in the process of swapping over what i can from my 300 TDI to my new acquired 2002 90 hard top and so wanted the twin batteries.
Followed the hand book - switch it on then off and remove the key. I took this to mean setting II with the ignition lights on only to set the alarm off. In the end i tried setting I and then took the battery cables off - success Very Happy
All the best
Mark
Post #34456 14th Jun 2010 9:31pm
