![]() | Home > Wheels & Tyres > Which spare wheel carrier? |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
Strength is even better.
No drilling of new holes. In some cases an existing hole needs to be drilled a bit bigger. WANTED: SII or SIII in max 1.5k |
The only thing I can think of is because you can't open the carrier from the inside, but that only applies to station wagons with seats in the back. Russell
2011MY 110 XS USW Black |
Well 8 years+ with Safari Equip standard wheel carrier, modified for radio mounts 150,000 miles. With a lot of those miles on rough tracks. Zero problems.
OK powder coating has started to go but I can live with that, or take it off and get it recoated |
Missing reflector. Do I win a prize? ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Reverse light and Fog lights are the wrong way round for right hand drive countries.
Yep and the reflector missing. |
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 ![]() ![]() |
Had a look on your site - when are you going to have it translated in English! Which one do I select for black Powder Coat - and how long will it take to arrive - also I assume it comes with a mount for the wheel nuts etc... finally does it first preexisting fixing or does the rear cross member need rilling? Matt |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17565 ![]() ![]() ![]() |
If there was a prize, you would have won it! |
Use Chrome and it will translate it for you although a little strangely at times! And as we can do most of the Nakatanenga stuff, they eventually end up on our website but only in English. It takes me enough time to do it in one language never mind in any other as well ![]() ![]() Barbara |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1945 ![]() ![]() ![]() |
The hinged number plate
![]() Do I win?? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
Anyone??? |
Cannot agree more with Matt. A very respectable seller like Nakatanenga with lots of out of Germany customers should have a English language tab on their website. Take the example of another German seller like Entreq, they have an English version, even if it is far from perfect. But we would not expect absolute perfection, but at least would expect that if you type "wheel carrier" into their search engine, you would get a result and a more or less decent translated description. Which is not the case now with Naka. ![]() I find it great that Leeds are offering some of the Naka and Entreq gear, but it would be nice to be able to canvass the entire Naka website in English. This would not have to be in any way negative to UK sponsors business I think. Hope someone at Nakatanenga reads this and gives it some thought. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
No experience of the product, but the top two vehicles pictured in that link (at least) are illegal on UK roads as shown (missing or mismatched reflectors, and/or obscured light units). |
But that's solvable and a common issue with many swc's apparently.
The price seems quote fair, cheaper then most, so I wonder about the quality. Hence my question if anyone has experuence with the seller and/or their products. |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 ![]() ![]() |
I had that one on my 110 which another Forum member now owns, it was nicely made and the hi lift jack mount was a lot stronger than the Honda civic I backed into ![]() Despite hating powder coating it was pretty good on that, did find it had a bit of play on the pivot that bolts to the door, but for the cost i'd get another ![]() As for the reflectors I had stick on ones and just bought another set and stuck both on upward instead of across so perfectly legal ![]() |
