Home > Puma (Tdci) > Fiddly little clip part number?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all - anyone know what the part number is for the fiddly little clips that hold the rear quarter window surrounds in place on a 110 SW? I can't find the part number anywhere - looking on that online parts catalog until my eyes went square.
Appears one has given up the ghost and as a result the trim (window surround) moves all over the place.
Post #310753 22nd Feb 2014 11:38pm
JWL
Have you actually investigated it properly? It may just be dislodged or not quite in shape. Just a thought before you go and get some without really needing them.
Post #310756 22nd Feb 2014 11:52pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
I believe you will find them under this number MWC6203 Thumbs Up
Post #310759 22nd Feb 2014 11:58pm
ericvv
Post #310783 23rd Feb 2014 5:56am
bear100
That's the one ericvv Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #310788 23rd Feb 2014 7:24am
eutek
Thanks everyone for the help in locating the name of this clip.
I did check, figured at first that the trim just worked loose, but the top clip appears to have snapped in half.
Once this is sorted there will be one less rattle in the 110 to deal with, on to the next mysterious noise... Smile
Post #310843 23rd Feb 2014 9:41am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
They are actually cable clips, used for clipping cable to steel beams of angle. Two of mine snapped, went to local electrical factors and got them for free, as it would cost more in paper than the items. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #310852 23rd Feb 2014 10:21am
eutek
Hi all...
So, the clips came in the post, and turns out they're a bit too small. The fact that the pic was posted next to a ruler of some sort should've been enough to clue me in, but... Embarassed
Did a bit more research, and found BTR6682 - these appear to be the same clips that I have - perhaps mine are a bit longer.
The thing is... how on earth do you re-attach the trim piece with these things? It can't be rocket science, but the answer eludes me. Neutral
If I insert them into the brackets in the trim and try to force them back on to the rail that makes up the structure around the window, they just get pushed all the way back in the bracket and close - too tight to fit anything in.
Maybe I'm using the wrong part?
Yes... I could take the other trim piece off and have a look, but I'm afraid that my remaining good clips will also spring off into the ether.
* doh, think I just found them - they might be mwc6204.... ah never mind - same part.
Post #313101 3rd Mar 2014 12:45pm
rtm89
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
I do think the BTR6682 is the right part number for the rear quarter windows. I unfortunately have a brain full of Land Rover part numbers.
As for the fitting side that isn't my speciality but that's definitely the number!
Sorry I can't be more help.
Post #313107 3rd Mar 2014 1:22pm
mk1collector
Try putting them on the window structure first then pushing the trim on
Post #313129 3rd Mar 2014 3:36pm
eutek
Hi - was doing that, but the wrong way, finally dawned on me how to do it.
Sometimes things are so simple that I can't grasp the concept, I was thinking there had to be more to it than that!
Doh... a real Homer Simpson feeling.
Post #313143 3rd Mar 2014 4:32pm
