Home > Tdi > Timing belt wear questions
Page 2 of 2 <12
neilly
United Kingdom 1987 Defender 90 300 Tdi ST Epsom Green
OK, just looked in the workshop manual,
tensioner Bolt 45Nm.
Idler stud 10Nm.
Idler Nut 45Nm.
How is that meant too work then. I replaced the stud threadlocked it, and then when I put the nut on I did it up to 45Nm. You would have thought that the manual wold highlight that part instead of hiding it in the torque settings page.
Darn, maybe I need to go take mine apart now, although I cannot see any of the rubbish you could see through the wading plug hole.
FYI Mr Haynes does not mention the stud torque!!!!! only the idler nut and tensioner bolt!
Lesson learned read, read again and then read again.
Post #310509 22nd Feb 2014 9:29am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
I would leave it.
This was my warning sign.
Most probably the mechanic at LR over torqed it and it gave way when I did the cam belt on the next belt change.
I just think that this is a designed weak spot.
Luckily mine is purring like a kitten again.
Another designed weak spot is the light switch.
In 14 years I have replaced 4 on 2 different Defenders.
There is just to much current going through the switch.
I will now build in a relay.
Post #310545 22nd Feb 2014 11:52am
Page 2 of 2 <12
