Home > In Car Electronics > Battery Fumes and Compressor
Matthew_Mills
So, I'm fitting a Viair in the battery box... I've read various post and articles that suggest a remote positioning for the air intake to avoid moisture as the battery box gets wet - being a new Defender and doing little wading I'm not so worried about that issue...
However I am thinking that any batteries fumes in the box might be a greater issue - Do I add the remote air intake and position it external to the box?
Would compressing any fumes be dangerous - compressed Hydrogen is a bomb! But then the battery is vented - am I worrying something that will never happen?
Or should I remote locate the air intake because that's best practice anyway...
Thoughts and advice very much welcomed.
Matt
Post #309492 19th Feb 2014 12:25pm
Likeomg
a thermonuclear defender... just be sure theres no uranium 238 about
i don't know about the fumes given but what about under the drivers seat?
Post #309519 19th Feb 2014 2:24pm
Matthew_Mills
Likeomg... Thanks for the comments - I don;t think it will go nuclear but any explosive gas under compression would not be great. The under seat box is pretty much full of 'electrics' I've looked and moving them around but it seems a huge efforts when there is the perfect space in the passenger side box...
Post #309536 19th Feb 2014 3:45pm
if it's the OEM battery then it has a small tube/vent that passes through the battery box to the outside to vent any fumes from the wet battery. (Gell batteries are sealed.)
just to add the LR precision engineered battery box does allow some air movement unless you use expanding foam Thumbs Up
Post #309588 19th Feb 2014 6:35pm
What Steve said above. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #309594 19th Feb 2014 6:45pm
Matthew_Mills
I guess the thread is just do it... I might just relocate anyway, just to be safe on both the gas and water front!
Thanks chaps for the contributions...
Post #309721 19th Feb 2014 9:39pm
