Home > In Car Electronics > Battery Fumes and Compressor |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2651 |
a thermonuclear defender... just be sure theres no uranium 238 about
i don't know about the fumes given but what about under the drivers seat? |
19th Feb 2014 2:24pm |
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 |
Likeomg... Thanks for the comments - I don;t think it will go nuclear but any explosive gas under compression would not be great. The under seat box is pretty much full of 'electrics' I've looked and moving them around but it seems a huge efforts when there is the perfect space in the passenger side box...
19th Feb 2014 3:45pm |
if it's the OEM battery then it has a small tube/vent that passes through the battery box to the outside to vent any fumes from the wet battery. (Gell batteries are sealed.)
just to add the LR precision engineered battery box does allow some air movement unless you use expanding foam |
19th Feb 2014 6:35pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20540 |
What Steve said above. No Guts, No Glory.
19th Feb 2014 6:45pm |
I guess the thread is just do it... I might just relocate anyway, just to be safe on both the gas and water front!
Thanks chaps for the contributions... |
19th Feb 2014 9:39pm |
