Home > Puma (Tdci) > Questions on gearbox to transfer box adaptor lubrication?
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Hi everyone.
The have been a number of threads on this adaptor with reference to failing/lack of lubrication.
The owners manual lists the recommended lubricant.
However, I have a couple of questions:-
1. In this something that can only be lubricated on assembly? Or is there a fill point/grease nipple?
2. If there is a user service point - how often should this be done? Is it part of the service schedule?
3. If not has anyone considered tapping a hole for a grease nipple? Got photos of the article in question - in pieces?
Regards
Mark.
Post #309117 18th Feb 2014 1:24pm
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
My Defender (Td4 my2009), about three months ago was recovered in a workshop to install the ATB diff in the LT230 transfer box. I ask to check for wear or corrosion the output-shaft and made a mod to allow proper lubrication.
I was extremely surprised because the guy who did the job found a kind of rubber "sock" filled of grease placed around the output-shaft.
This mod was probably made by the dealer a couple of year ago when he did clutch replacement.
I know that Ashcroft is working to develop a lubrication kit for the output-shaft.
Post #309283 18th Feb 2014 8:19pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
So currently there is no lubrication for this shaft right? Mine was destroyed at 25k miles and splines sheared off and replaced.
Post #312229 28th Feb 2014 4:03am
Correct. It can only be lubricated prior to the gearbox and transfer box being bolted together. It runs in a large empty dry space and is inaccessible without dropping the t-box out.
On the basis of the relatively poor stats available, 2010 MY vehicles seem to be the ones most likely to suffer failures of this shaft.
Post #312251 28th Feb 2014 9:19am
MD5 wrote:
My Defender (Td4 my2009), about three months ago was recovered in a workshop to install the ATB diff in the LT230 transfer box. .....
How do you find the ATB in the t-box? Can you give us an assessment/review please? I'm thinking of doing the same myself.
Post #312253 28th Feb 2014 9:20am
ronwong
mine is a MY2012. And it failed at 1 year. my mechanic replaced the part the same way with no lubricant Sad
Post #312254 28th Feb 2014 9:21am
munch90
I took mine to bits to check it , found no wear just bit of brown dust so packed it with grease and put it back togather
Post #312269 28th Feb 2014 10:00am
AlanH
Australia
My 2010 110 suffered from horrible backlash and the stealer here in Perth WA had it in to fix under warranty. I chatted with the service foreman who reckoned that there was no requirement for this shaft to be lubricated although I'd definitely seen a Castrol grease recommended somewhere, maybe in the manual or on the net.
A few months later it turned out the transfer box was whining and they decided to change it and given the mileage (kilometerage) mine had done it should have had a recon box but none were available. I pleaded with this service foreman to please please please grease this during re-assembly and he assured me afterwards that it had been done.
Impossible to check so I'll have to wait and see.
AlanH.
PS. I visited a so called LR expert here in Perth not long ago who told me that ALL Transits were suffering from gearbox failure and it was all the fault of this shaft even though they haven't got a transfer box....... Surprised
Post #312277 28th Feb 2014 10:33am
munch90
they haven't got the shaft either
Post #312294 28th Feb 2014 11:37am
AlanH
Australia
Quite right and he didn't have much idea about anything. Very Happy
AlanH.
Post #312299 28th Feb 2014 11:49am
