Home > In Car Electronics > interior light
Page 1 of 3 123>
FOOTEY
Scotland 2009 Defender 90 Puma 2.4 HT Tamar Blue
interior light
My interior light will not switch on when door is opened unless ignition is on !! . Puma 09 van. Any ideas please?
Post #308859 17th Feb 2014 2:20pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Think it must have been wired up incorrectly. The actual trigger for the light coming on is the earth, in both instances. The live should be permanent, so somewhere, the live has been connected to an ignition switch. If it is connected straight to the back of the barrel, you probably have something else on permanently. 1998 110 300Tdi White Hard Top
Post #308876 17th Feb 2014 3:29pm
Laurie
Has it always been tike that?
Post #308880 17th Feb 2014 3:34pm
VeeTee
Netherlands
Is not this controlled by the Alarm ECU also? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #308896 17th Feb 2014 4:09pm
JWL
I'm sure you can alter the settings for the interior light via a diagnostics plug in, I know you can alter settings on a Td5 with a Nanocom.
Post #308899 17th Feb 2014 4:13pm
FOOTEY
Thanks for help
Its been like this since I bought it
The light works on/off manually without ignition
dont have alarm
Like the possible computer diagnostic idea/
Been sugested meant to avoid farmers leaving door open and flattening the battery!! Although he/she can leave the lights on, no ignition required!!
Post #308954 17th Feb 2014 8:27pm
FOOTEY
Thanks
spoke to LR say it may be a diagnostic fix . whats a nanocom, pardon my ignorance
Post #309163 18th Feb 2014 3:14pm
JWL
The Nanocom is for the short description, a stand alone diagnostics box that plugs into the OBD(on board diagnostics) socket. I mentioned Nanocom as I have an older version which is more compatible with the Td5 and reads the Land Rover foibles of programming which some general OBD readers don't.
A trip to an independant LR garage would sort it for little money or put a post up here on the forum to see if someone local would be prepared to help you out for a beer token or two.
Post #309177 18th Feb 2014 3:49pm
Merlin
My driver's one has always been a bit dickey since new. My solution is to 'exercise' the switch on the door. Maybe a squirt with something would be better.
Merlin
Post #309201 18th Feb 2014 5:04pm
Have you tested it by touching the door switch wire manually to the earth of the body in a suitable area? If it still doesn't work then you know it's not the switches if you check them.
I'd also take out the fixture and check the earthing and for power.
It's permanently live and earth switched but there is an earth terminal on the back plate of the light and needs to be tightened well (within sensible reason)
Some good photos here https://www.defender2.net/gallery/thumbnai...amp;page=3
Bear in mind I have some connections there that are non standard however the black plug on the backing plate is the standard earthing I mention above.
There should also be a white plug with two wires one, permanent live the other permanent live from the alarm system.
If you say the light comes on manually that is working fine it's the alarm system / door switches that seem to be the issue.
You can check these connections all the same for voltage and the earth continuity from the earthing plug on the backing plate to the door switches to check for a wire break.
If it still doesn't work if you open any door then that's unlikely. No Guts, No Glory.
Post #309237 18th Feb 2014 6:23pm
FOOTEY
All works normally when ignition is on, so the circuit and switches all work. The light works without ignition.With the switch in the centre position the door switches do nada.Very frustrating Big Cry
Post #309313 18th Feb 2014 8:01pm
Lorryman100
Does the interior light dim before it goes out completely or is it either on or off?
Also remove the right side speaker next to the fusebox and have a look up the bulkhead for a green box with 2 plugs. It looks the same as the pic below but on the right side as the pic depicts a LH drive.
Post #309315 18th Feb 2014 8:02pm
FOOTEY
Thanks Lorryman
light dims and goes off{ when ignition on }
suppose I look for said green box...then what! Looked at obd readers but conclude that assuming I get a fault code I aint gonna be able to write a correction.
Carryin a torch every time I go out is doin my nut. A long shot may be suggesting the fault may be original and therefor warrantable Rolling with laughter
Post #309337 18th Feb 2014 8:33pm
Lorryman100
The presence of the green box (10AS), will help decide on whether or not a diagnostic tool will help in fixing your issue. Note the interior light settings in the 10AS settings page below, normal or smart.
Post #309343 18th Feb 2014 8:52pm
Is there any possibility the live feed from the 10AS has been intercepted so to speak meaning it's ignition switched rather than from the AS?
There is certainly more than meets they eye to this, there is either a system fault a possible short or it's been fiddled with.
I've done quite a bit of work on the interior lighting system and never encountered an issue from the 10AS ever. No Guts, No Glory.
Post #309359 18th Feb 2014 9:24pm
Page 1 of 3 123>
