Home > Technical > Land Rover Tow Balls |
Alicat Member Since: 25 Nov 2013 Location: Hertfordshire Posts: 135 |
My Defender was fitted at the dealer with a LR drop plate and tow ball. Is the LR tow ball compatible with ALKO stabilisers, or do I need to change it for an ALKO compatible one?
Thanks Tony |
14th Feb 2014 10:28pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Mine is got a bit of extra neck on it measure it to be sure
14th Feb 2014 10:45pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Ideally you need the Alko ball which has a longer neck to fit the Alko hitch with the stabiliser fitment. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
14th Feb 2014 10:50pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Try it.
Mine had an OE towball fitted. Takes out Alko hitch on the caravan easily. |
14th Feb 2014 10:58pm |
£12.95 from towsure
15th Feb 2014 8:25am |
not a answer or help
we had a transit in during the week where the tow ball itself only had one bolt in it and that was loose allowing the ball to twist round ,, but still had a trailer (not a small one either ) on it when they pulled up and asked if it was ok to use !!!!. |
15th Feb 2014 9:16am |
Thanks all, a mixed response then, but as an ALKO unit is not that expensive then it looks like that is the way to go.
Thanks all Tony |
15th Feb 2014 11:26am |
