Home > Puma (Tdci) > Dipped Headlights Stopped Working - help |
http://www.defender2.net/forum/topic16451....ght+switch
http://www.defender2.net/forum/topic24666....ght+switch http://www.defender2.net/forum/topic13683....ght+switch If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
13th Feb 2014 5:40pm |
gprich Member Since: 14 Jun 2013 Location: East Devon Posts: 42 |
It is almost certainly the main lighting switch (stalk) - same one been used for years so at least it's cheap and available and a fairly easy job to do yourself.
13th Feb 2014 5:41pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2751 |
relay your headlights as per the threads K9F linked too, erases the problem completely for the future.. Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
13th Feb 2014 5:55pm |
Or replace with LEDs to reduce the current draw through the switch perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
13th Feb 2014 5:58pm |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 |
Thanks for the links K9F
So it looks like I need to change the switch as there's no relay right? How straight forward is this? Plug and play or soldering required? Also does the steering wheel need to come off to do this? Thanks guys Mark |
13th Feb 2014 6:31pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17354 |
No soldering required, it's all plugs. Wheel doesn't need to come off but removing it does make the job a lot easier (it's very easy to remove the wheel).
13th Feb 2014 6:54pm |
Many thanks Blackwolf.
That sounds like something I can take care off on Saturday myself. Thanks to all of you for your replies. Mark |
13th Feb 2014 7:17pm |
Josh K Member Since: 01 Nov 2013 Location: Herefordshire Posts: 266 |
I had this issue last month and bought a new switch. However when the truck was in for its service whilst awaiting delivery of the part, the garage repaired the switch with some solder so now I keep the switch as a spare in my truck tool box just in case the switch goes whilst out and about. Always better to be prepared, saves having to drive home with the sidelights which far too many members on this site have had to do 2007 (57) Defender 90 (Sold)
Looking for another to replace it. The road less travelled.... is a muddy one! |
13th Feb 2014 8:33pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
Better to be prepared and RELAY the lights. solve the problem, not the symptoms
14th Feb 2014 11:44am |
