Home > Maintenance & Modifications > Need some 5A single connectors, please?
ZeDefender
Hi all Cool
I'm looking for some single cable connectors (2x male and 2x female) for 6mm2 cable and up to 5A.
The reason is that I've installed a 12V to 24V converter next to the battery for my LED headlights and I'd like to be able to quickly "rewire/replug" directly to the battery in case the converter goes tits up.
Single 2.5A SuperSeals aren't beefy enough (and I can't find the right search terms) - any suggestions please?
Many thanks Smile
Matt Tell someone you love them today because life is short.
Post #307454 12th Feb 2014 2:04pm
Martin
Site Admin
Superseal are 14A rated, are they not?
I'm sure Tim @ Mobilecentre will do something suitable.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #307456 12th Feb 2014 2:12pm
Tiger
Simple bullets?
Post #307457 12th Feb 2014 2:14pm
K9F
Bullets? More like mortar shells.....The yellow variety of bullets may just fit, mind you don't give yourself a hernia crimping them. Laughing
You'll be hard pushed to find anything small to acommodate a 6mm cable with only a 5 amp capacity, it'll be more like something out of Mary Shelley's Frankenstein. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #307467 12th Feb 2014 2:42pm
ZeDefender
It's 6mm square section - diameter is about 2.8mm Confused
I thought Superseals only went up to 2.5A - I just read 10A somewhere...
p.s. I solder everything Thumbs Up Tell someone you love them today because life is short.
Post #307471 12th Feb 2014 2:44pm
K9F
Re: Need some 5A single connectors, please?
ZeDefender wrote:
6mm2 cable
Matt you're still using a cable capable of carrying upwards of 34 amps for a 5 amp job? Smaller cable means more discreet subtle finish perhaps and more choice when it comes to connectivity?
You could potentially use something like this for easy connectivity and it'll be fused as well to protect whatever it's supplying dependant on what you want to achieve. You will just need two female sockets to revert back if need be, the bonus is you'll get to do a bit of soldering too.
http://www.maplin.co.uk/p/10a-fused-snap-i...itch-n94cz If you go through life with your head in the sand....all people will see is an ar5e!!
Post #307474 12th Feb 2014 2:51pm
ZeDefender
The cable is already in there (2.8mm diameter) - I originally bought it for another project for low voltage drop over 10 metres with higher 15-20A current. I know it's overkill but it was just handy when rewiring the lights Whistle
I mis-read the SuperSeal info in German as "2,5 AMP" - it's actually made by "AMP" and is the "2,5" model Thud
They actually are big enough to take the cable and take 20A.
Thanks Martin for making me look again Thumbs Up
Might buy them or similar from Tim now Mr. Green
Cheers all for the help,
Matt
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #307479 12th Feb 2014 3:00pm
