Home > Td5 > Rough on startup, no throttle response
Page 2 of 3 <123>
Mac87
Thanks, Pete. That's a shame, I was hoping it would work on mine as it's close by and a fair price. He's adamant that it will fit, but will stay clear if it's not advisable
Post #298355 13th Jan 2014 3:40pm
bell-auto-services
It will fit but its not really the best way to go, most only reprogram the mapping chip (29F200BT) via OBD to suite the defender calibration but their is also an 8 pin SOIC Eprom (93C66) in their that also should be converted at the same time to NNN500020 to match the calibration, this is a solder job and most dont get done.
Pete
Post #298356 13th Jan 2014 3:42pm
Mac87
Hi again all - unfortunately the problem persists! My local indy has been very helpful as usual, but have changed a number of things and it's still going on.
Things changed so far:
-ECU
-Glow plugs (3 weren't working)
-MAF
-Air temperature sensor
-Injector seals + harness
-Fuel filter
All to no avail. Any ideas gratefully received!
Post #302861 28th Jan 2014 4:32pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
What fault codes are stored mac, I take it a genuine maf sensor was used? Have the live readings been checked, cylinder balance etc?
Post #302918 28th Jan 2014 6:31pm
Mac87
As far as I'm aware there aren't any fault codes showing (it's still in at the indy). It will be a genuine MAF too, and I think all of the live readings have been checked. Next step looks to be looking for chafing in engine harness.
Post #302984 28th Jan 2014 9:26pm
Mac87
Did the fuel purge this morning after being left over night, still the same problem but ran normally much earlier than usual. So hopefully a search for air getting into the fuel may sort it
Post #304084 1st Feb 2014 1:14pm
bga86
Fuel filter housing have caused this issue for me in the past Thumbs Up
Post #304373 2nd Feb 2014 12:31pm
Mac87
Cheers, I'll start my search there Thumbs Up
Post #304422 2nd Feb 2014 3:33pm
Mac87
Back again! Everything feels pretty tight fuel delivery wise, can't figure out anywhere where air could be getting in. Found a couple of chafed wires under the drivers seat, wrapped these in insulation tape.
A couple of new discoveries : when it's running rough/very slow after starting up the speedo rushed up to 50mph then back down again, and also on about half revs there feels like a slight misfire and some blue smoke comes out the back until i rev it right up high then misfire/smoke clears. Totally stumped again!
As an aside does anyone know a good diesel/TD5 guru in Kent?
Post #306833 10th Feb 2014 3:15pm
Mac87
If its any help I found this on youtube and this is EXACTLY what my engine does when started from cold. The diesely smoke doesn't stop until it lets me rev it like at the end of the vid
Post #306941 10th Feb 2014 8:05pm
Alive Tuning
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Havana
Remove the serpentine belt and then start the engine from cold.
Wink
Post #306948 10th Feb 2014 8:17pm
bga86
What's the logic behind that Gary?
Post #307053 11th Feb 2014 7:08am
Mac87
Will give it a go when it stops raining, workshop is full of machinery!. Assume looking for a seized/seizing pulley?
Post #307513 12th Feb 2014 5:02pm
landy andy
Alternator knackered? Working hard to recharge battery after start up?
Andy
Post #307597 12th Feb 2014 8:17pm
Alive Tuning
Seriously, try it! It'll go straight to idle.
Then get some timing pins and reset your timing properly.
Post #307901 13th Feb 2014 9:18pm
Page 2 of 3 <123>
