Home > Maintenance & Modifications > Going deeper than 500mm
Page 2 of 2 <12
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
As a poverty spec runs 205's with a 500mm max depth and my 110 double cab runs 235's on HD springs from factory would that mean I should be able to go deeper standard Question
Post #305994 7th Feb 2014 7:48pm
g-mack
Supacat wrote:
http://www.telegraph.co.uk/motoring/news/1...escue.html[/url]
probably general public 4x4 owner seeing modified 4x4 (green laners etc )going through deep water and theing their x5 and tiguans can do the same!! My 109 thread
my youtube channel
Post #306002 7th Feb 2014 8:06pm
Nice link!
3. Don’t drive through fast-moving water, such as at a flooded bridge approach – your car could easily be swept away.
I've seen that done last weekend... I thought that is asking for trouble.
Less than a week later and I see this in the paper at the the same place. Rolling Eyes
 Chillin In The Backwoods🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #306008 7th Feb 2014 8:12pm
I'd imagine the difference if any would actually be very difficult to discern from the driving seat?
Do HD springs actually have a greater free length than standard or is it just a rate change?
Post #306102 8th Feb 2014 9:19am
familymad
Those lads in a TDCI defender rocked. Bet it steamed up for the rest of the year 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #306108 8th Feb 2014 9:41am
And was smelly - remember flood water contains all sorts on contaminates & in rural areas you will be wading through the contents of someone's septic tank ��
Post #306116 8th Feb 2014 10:06am
NoDo$h
Somerset Levels are currently a pleasant mix of septic tank, dead wildlife and slurry. Oddly enough I'm not wild about voluntarily driving through that.
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #306124 8th Feb 2014 10:51am
TJ101
Ain't that the truth Alan California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #306283 8th Feb 2014 6:54pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Iv had the water over the bonnet in my truck although it does start finding every way in
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #306625 9th Feb 2014 6:49pm
James MacKay
2009 Defender 110 Puma 2.4 SW Alpine White
I have made several crossings in and around the Okovango Delta where the water was easily 15 meters wide and 900mm deep pulling a 1 tone camping trailer no problems at all. the only modification I did was to add a Safari snorkel and I sealed the join near the wheel arch where the 2 molded pieces of plastic join.
Post #325891 24th Apr 2014 7:28pm
My RAI is not specifically watertight and I have had water up to the exterior door handles more than once. It is not a problem provided you know what you are doing and how to do it. It is the driver, not the depth, that is usually the problem.
Just remember with that sort of depth you are getting to the point you may have to open a door to flood the vehicle to stop it floating, and it takes a very long time to dry it out afterwards.
I've had water over the top of my wellies while driving my standard petrol SI before now. Much quicker to dry than the Puma!
Post #325899 24th Apr 2014 8:16pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
There is nothing to seal the clutch on my Def 2012.
No intention to go in water to.
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #326144 26th Apr 2014 2:52am
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Fair play to the guy in that video...
I wouldn't take my TDCi through that. He either knew how deep it was and was playing up for the camera or he was a bit stupid and could have wrecked his truck.
I, like the rest of you, would like to know what issues he's had since! Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #326572 27th Apr 2014 10:03pm
Page 2 of 2 <12
