![]() | Home > Td5 > Wipac Crystals |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
sounds like the stalk is duff for starters, at least in high beam, I would start there and see what that does 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
Ruari Member Since: 10 Dec 2013 Location: Ayrshire Posts: 50 ![]() ![]() |
Are you dipped beam, coming on or is that just the side lights light up 2-3m?
Do a quick test with the volt meter or test light on the back of the stalk. It could be the headlight relay. I had the same problem - it was the switch stalk - full / dip beam / indicator. I could only drive by holding on the full beam. It's very easy to replace, remove the cowling around the steering column, Switch stalk is a couple of screws and a plug. Just make sure you order the correct era of switch stalk as the plug changed shape. |
Ragerover Member Since: 26 Dec 2013 Location: In a land far far away Posts: 145 ![]() ![]() |
what he said easy job and common problem
iirc padocks are the cheapest check which plug is on the back as they differ |
bigscoth Member Since: 05 Feb 2014 Location: Derbyshire Posts: 27 ![]() ![]() |
Thanks very much...sounds like that's the culprit. I'll get one ordered and give it a go... |
Cheers Ragerover... Pm sent re: your roof. I'm around all afternoon if you pm me your number I'll give you a call |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
This may be a silly question but are you putting the master light switch two clicks forward?
Or the master light switch might be gone, on dim dip the forwards position for main beam won't work 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Graft99 thanks I'd already bought the new stalk and found the 2nd click on the master stalk. Still no joy so I fitted the new stalk and all sorted. Thanks for all your advice folks :/)
