Home > Td5 > Wipac Crystals
bigscoth
Wipac Crystals
Hi there,
Just bought an '03 90 with soft top. It's had LED side lights and wipac crystal headlight conversion but there are 2 problems:
Full beam can only maintained by pulling the stalk toward the steering wheel. Full ram is super bright so the headlight must be working.... But...
Headlights in dipped setting don't illuminate further than 2-3metres.
Any thoughts on what's going on?
Thanks
Post #305473 5th Feb 2014 10:39pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
sounds like the stalk is duff for starters, at least in high beam, I would start there and see what that does 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #305507 6th Feb 2014 6:58am
Ruari
2000 Defender 110 Td5 HT Alpine White
Are you dipped beam, coming on or is that just the side lights light up 2-3m?
Do a quick test with the volt meter or test light on the back of the stalk. It could be the headlight relay.
I had the same problem - it was the switch stalk - full / dip beam / indicator. I could only drive by holding on the full beam.
It's very easy to replace, remove the cowling around the steering column, Switch stalk is a couple of screws and a plug. Just make sure you order the correct era of switch stalk as the plug changed shape.
Post #305564 6th Feb 2014 10:30am
Ragerover
what he said easy job and common problem
iirc padocks are the cheapest
check which plug is on the back as they differ
Post #305587 6th Feb 2014 12:30pm
bigscoth
Thanks very much...sounds like that's the culprit.
I'll get one ordered and give it a go...
Post #305595 6th Feb 2014 12:54pm
bigscoth
Cheers Ragerover... Pm sent re: your roof. I'm around all afternoon if you pm me your number I'll give you a call
Post #305598 6th Feb 2014 12:57pm
grafty99
This may be a silly question but are you putting the master light switch two clicks forward?
Or the master light switch might be gone, on dim dip the forwards position for main beam won't work 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #305653 6th Feb 2014 5:48pm
bigscoth
Graft99 thanks I'd already bought the new stalk and found the 2nd click on the master stalk. Still no joy so I fitted the new stalk and all sorted. Thanks for all your advice folks :/)
Post #305721 6th Feb 2014 8:52pm
