Home > In Car Electronics > Supply permanent live to headunit during cranking
Page 1 of 3 123>
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Has anyone done this?
I'm talking about the main power source for the head unit, not the ignition feed.
Right now if I crank too early, my 7" flip out requires a hard reset (no jokes please Laughing )
Post #304090 1st Feb 2014 1:28pm
You can but you'd have to make sure you have it turned off manually or you'd get battery drain. As is it's designed to only come on with ignition, it's already got a permanent live but it's switched via ignition on. No Guts, No Glory.
Post #304099 1st Feb 2014 1:59pm
mrd1990
I've been under the impression the permanent live only goes off during cranking?
If I take the key out before the screen has fully opened, it pauses for a second then folds back and all is good, if I crank before it's fully opened, it crashes.
Highly frustrating as it takes around 8 to fully turn on, it delays going off by several seconds when the ignition is turned off so plenty of time for cranking.
I'm wondering really, is it voltage drop that's doing it or is the permanent live cut off to help the battery start the engine?
Post #304134 1st Feb 2014 4:39pm
Voltage drop, but it should carry on in its motion straight away when power is restored.
Pretty much immediate really, so it's down to the. Electronics of the HU.
I know the issue your talking about, must be very frustrating! No Guts, No Glory.
Post #304145 1st Feb 2014 5:18pm
landy andy
Would have thought you could wire a live direct from battery that is activated by ignition live relay that has a delay so no power drop during cranking.
Andy
Post #304147 1st Feb 2014 5:21pm
Shouldn't do it though anyway, with mine if it's coming out and I crank it over it stops for a split second and then carries on.
Same with the opposite if I close it down and shut the ignition and engine off at the same time immediately it'll still close with the engine and ignition completely off. No Guts, No Glory.
Post #304148 1st Feb 2014 5:25pm
I think you'll find that there is already a permanent live in the standard connector, and your problem is simply that when you crank the terminal voltage is being pulled down low enough to cause the unit to drop out.
You may find that running a heavy gauge wire straight to the battery helps.
You could also as a test try starting with a second vehicle (with the engine running) connected with jump leads, since it is likely that this will hold the terminal voltage up whilst cranking.
Post #304204 1st Feb 2014 7:03pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Has this always happened?
How old is the battery?
Have you checked battery voltage at rest after a trip and first thing in the morning, before starting up? LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #304212 1st Feb 2014 7:36pm
mrd1990
The battery is good, started up fine after a week standing unused in Scotland over Christmas and the problem still persists after a long trip.
This has always happened since I installed the HU. I'm convinced I've read somewhere that the live feed is cut during cranking. Voltage drop is just as likely but I want to rule out everything else first, having said that the handbook says 10.5v as the minimum operating voltage.
A small second battery looks like the solution at the moment..
I will take the dash off and try some tests tomorrow if the rain holds off
Post #304245 1st Feb 2014 9:13pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
https://www.defender2.net/gallery/albums/u...lock~0.JPG
this works volt drop problems
sorry the pic to small will try to sore it out
Post #304315 2nd Feb 2014 8:50am
dorstsmith2
https://www.defender2.net/gallery/albums/u...lock~1.JPG
NO can not fix it Mad
Post #304318 2nd Feb 2014 9:00am
K9F
I work in the marine industry and these are good and would undoubtedly suit your purpose.
http://www.boatlamps.co.uk/contents/en-uk/d191.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #304319 2nd Feb 2014 9:01am
dorstsmith2
see computer you will never win Mr. Green Mr. Green Thumbs Up
Post #304336 2nd Feb 2014 10:30am
mrd1990
So the 40v cap will give the radio priority over the starter motor?
I've read that diodes can be damaged by cranking and fail leaving battery drain?
I'll build it an see what happens, struggling to find the diode, any other diodes I can use that are available on amazon? Laughing
Post #304893 3rd Feb 2014 10:48pm
K9F
Try Maplins...... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #304991 4th Feb 2014 11:13am
Page 1 of 3 123>
