![]() | Home > Puma (Tdci) > Air Con |
dulwich man Member Since: 29 Nov 2011 Location: Dulwich Posts: 64 ![]() ![]() ![]() |
I have a 2009 110sx. This has been serviced on a regular basis,however I presume that checking the air con is not part of the service schedule. i had to have the engine out out twice under warranty work so i presume that they will have to have diss connect the air con and therefore fully recharge the system. I do run the air con during the winter months as it helps clear the screen.
However I have read that air con should be separately serviced/topped up every 3 years and telling if it is just a little inefficient over a period of time is hard to tell. Or is this just sales talk? All views welcome Ta |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2770 ![]() ![]() |
you can buy the air con topup cylinders yourself from halfords etc, otherwise Kwikfit/mot centre type place will do them for a bit more, no biggie...
my car is 4yo and its still cold enough to fog up the windscreen on the outside if i only have it pointing upwards, never been degassed Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Just a quick question on air con, should the compressor cycle on and off under normal operation or just stay on and maintain its own pressure regulation.
As this is my first lr with a.c. I was`ent sure if all was ok or not and it may be over gassed... |
pump does cycle on and off yes
Thanks just needed to know, one thing off the list
