Home > Wheels & Tyres > Wheel loads...
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Wheel loads...
Just struggling what is right in selecting the right wheels.
What wheel load is needed by a max. axle load of 2.200 Kg? (Defender 130).
Is there any law or insurance policy that refers to this?
Landrover uses only the HD steel wheels (Rated 2.200 Kg. each), but I have read 1/2 of max axle load is only (lawful) necessary.
Thanks,
Q.
Post #303359 30th Jan 2014 11:18am
jimbob7
Boosts are rated at 860kg (ish). Pov.spec,ftw. 2006, 110,TD5.
Post #303363 30th Jan 2014 11:24am
TopQ1967
Yes and Blindo's 1550 Kg each..
But what is needed total max axle load or 1/2 axle load?
Post #303597 30th Jan 2014 9:47pm
mick
Don't know the weight answer but I went for Blindos to be sure Thumbs Up
Post #303602 30th Jan 2014 9:58pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Re: Wheel loads...
Thanks,
Q.
Can't help you with an answer, but in this case, it might be worth asking on the lrch forum?
Or maybe even better, your insurance agent?
Post #303604 30th Jan 2014 10:03pm
jimbob7
Bare minimum half axle load (if you can find such a wheel), BUT,I dont think your gonna get a specific answer, to many variables, legalities can vary from one country to the next also tyres have load ratings.
So in answer to your question "what is right", if you only use it on the road (no load), half axle weight,but be aware of potholes and high kerbs,if your carrying a ton of equipment across the Alps,HD steel wheels.
Not so much, "what is law", as "what is common sense". Pov.spec,ftw. 2006, 110,TD5.
Post #303607 30th Jan 2014 10:09pm
