Home > My Defender > At the dealers waiting for some options before collection!
Page 2 of 2 <12
I have a used Genuine LR 110 NAS step here in great condition if you are stuck
Post #303392 30th Jan 2014 12:21pm
RustyM
England 2016 Defender 110 Puma 2.2 XS CSW Corris Grey
Thanks Go Beyond I am glad there is such a great community on here with members who offer help like yourself Bow down I will let you know, thank you for the help Thumbs Up 90 & Wolf
110 XS
Previously owned SI SII SIIa SIII & Light weight (air portable)
Post #303394 30th Jan 2014 12:24pm
RustyM
RustyM wrote:
I know there is a dealer near to me on here that everyone knows but I can not recall the name anyone?
Found it.... should have gone to see Jeremy @ Hadley Green LR Embarassed 90 & Wolf
110 XS
Post #303401 30th Jan 2014 12:38pm
RustyM
So a big thanks to Mike our resident from JLR on the forum Bow down As I should have my rear step and electrics tomorrow as long as all goes to plan Thumbs Up
Shame it happened but good to see that JLR are trying hard to sort it out for me. 90 & Wolf
110 XS
Post #303503 30th Jan 2014 7:15pm
Porny
Site Sponsor
What about the rear lights?
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #303517 30th Jan 2014 7:50pm
RustyM
Rear lights Bow down you are correct , indeed the indicators are positioned lower outside not lower inside like the digram Shocked Normal bulb with clear lenses Big Cry can you pm me a cost of a LED indicators only kit (lights, relay and wiring) please?
So it is back to get the step and bits fitted and I am picking it up again in the morning Thumbs Up 90 & Wolf
110 XS
Post #303915 31st Jan 2014 9:16pm
Porny
Site Sponsor
So the dealer has failed to follow the fitting instructions then Shocked
Interestingly... I'd be seriously worried they have bodged the panel behind the indicator... read as - if they have fitted the 'filament' type indicator on the outside edge they 'will' have bodged the back of your Defender!!" - if I am right, I would be rather annoyed!! Twisted Evil If the plinth overhangs the edge of the bodyworth - they may have 'just' drilled a couple of new holes.... or it could be worse.....
The reason the indicator is supposed to be moved inboard is that filament NAS lamp does not fit in the original hole (i.e. where standard indicator fits).. so this leads to people badly increasing the size of the hole.
See below picture - this was done by a well know LR specialist when the vehicle was new!!! (which I've got the task of putting right). 6 holes... for 2 screws. Cut with a blut knife.
Also, they could not have used the proper multi fit plinth as the filament NAS lamp will not fit.
Basically, the LR kit puts the indicators into the plinths originally used by the Reverse/Fog lamp as the plinths and holes behind the plinth are designed for the bigger bulb/filament type lamp.
They then use a multi hole plinth that lines up with the mounting holes for the original small lamps. There is no need to make the hole in the LR any bigger as the back of the LED lamps are much shallower, and do not protrude... hence why the reverse and fog get put on the outside. Stop and tail stay in the original place.
Pinched from Tim's site - this is the proper plinth for a LED lamp... the multiple holes allow for fitment without modification.
This might make more sense if I get some photo'.... or, I would unscrew the indicator and have a look behind.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  IRB
Post #303960 31st Jan 2014 11:44pm
Porny
Site Sponsor
Also...
If you go to here:
http://topix.landrover.jlrext.com/topix/vehicle/lookupForm
(you do not need to log in)
Select Defender/L316
And then 2010 (must use 2010 option - as for some reason isn't on for any other year)
Click Find
The top right - click "owner"
Then "Accessory Fitting Instructions"
Then "Auxiliary Lighting"
Followed by "2. VPLDV0030 - LED Rear Light Kit"
Or actually - SCRUB THAT you could just click here lol - didn't think it would work:
http://topix.landrover.jlrext.com/topix/co...tabs=false
You can then show the dealer the guide... Rolling Eyes
Ian IRB
Post #303966 1st Feb 2014 12:26am
RustyM
Hi Ian,
Thank you so much for your help Bow down The parts and tech had no idea! I am so lucky that the tech drilled the incorrect mounting bracket to make it fit Rolling with laughter So I removed the lights and showed them the topix digram and 1/2 an hour later it sank in they need to order the correct mounting bracket for the outside (now relocated by me in the carpark) fog and reverse LED's Big Cry
I have to say I was worried they had done what you had pictures of but I was lucky Exclamation I will load some pictures of before and after when done. 90 & Wolf
110 XS
Post #304161 1st Feb 2014 5:51pm
Porny
Site Sponsor
No problem....
Will drop you a PM ref LED rear indicators to make the rear of yours Full LED.
Ian IRB
Post #304624 3rd Feb 2014 7:29am
2014110XS
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I have the same problem with my new 110, can you PM me the price of the LED indicators.
My dealer has position the indicators on the outside, will have a look how they've done it.
Thanks
Post #322335 8th Apr 2014 9:13am
Porny
Site Sponsor
PM sent
Regards
Ian IRB
Post #322343 8th Apr 2014 9:46am
Page 2 of 2 <12
