Home > Puma (Tdci) > Fitting a decat pipe .. on the drive |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2645 |
exhaust place... i found it quite tricky.
29th Jan 2014 8:44pm |
With the crossmember and front propshaft disconnected the catalytic convertor can be removed on the drive. The engine itself may need pressure applied with a jack to give you the extra 5mm room to manipulate the cat out. It can be difficult but achievable.
Few tips.... http://www.defender2.net/forum/topic26399.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
29th Jan 2014 8:51pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20480 |
The x member can be a pain to remove sometimes so I've heard, but not always.
I've just left my cat as standard and put in a straight trough centre section. Can't be bothered to be honest. Modifying cats what next birds? No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
29th Jan 2014 10:49pm |
