Home > Puma (Tdci) > Fitting a decat pipe .. on the drive
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi .. Is it possible to remove the cat and fit a decat pipe to a 2.4 puma without use of ramps or a pit? Preferably I'd like to keep the cat and pipe in one piece. (Or am I just better off getting an exhaust place to do it for me?)
Thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #303229 29th Jan 2014 9:37pm
Likeomg
exhaust place... i found it quite tricky.
Post #303235 29th Jan 2014 9:44pm
K9F
With the crossmember and front propshaft disconnected the catalytic convertor can be removed on the drive. The engine itself may need pressure applied with a jack to give you the extra 5mm room to manipulate the cat out. It can be difficult but achievable.
Few tips....
http://www.defender2.net/forum/topic26399.html
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #303239 29th Jan 2014 9:51pm
The x member can be a pain to remove sometimes so I've heard, but not always.
I've just left my cat as standard and put in a straight trough centre section. Can't be bothered to be honest. Whistle
Modifying cats what next birds? Rolling with laughter WeWillWin🇬🇧🇺🇸
Post #303300 29th Jan 2014 11:49pm
