![]() | Home > Puma (Tdci) > Rear twin shock |
Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88 ![]() ![]() ![]() |
Hello,
Does anyone know about this parts: http://www.terrafirma4x4.com/products_php.php?cat=1&grp=16 Could it be fitted on a Puma? Thanks ![]() |
Apynala,
I think the clue may be in their advertising "Accessories and Upgrades for Land Rover Vehicles" and the important note about 30 mm spacers being required for standard Land Rover alloys. There is also a drop down list of a multitude of countries you can contact Terrafirma product suppliers through. Below is the link for UK why not give them a call? http://www.terrafirma4x4.com/distributors....1271753275 ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Hello, My def has been fitted with Wolf rims and 235/85 16 Michelin O/R so I phoned to a french dealer and: - The lower part doesn't need to be welded on the axle ![]() - He will give me an answer in 2 days if it can be fitted on my truck. ![]() I will tell you. Thanks |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
pay attn to the fuel filter location. For example those sold by llama4x4/gwyn lewis do not fit stright away and you need to chop the FFilter protection etc Puma 110" SW
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
The Devon 4x4 version needs the bottom mount welding ![]() ![]() |
TallPaul Member Since: 28 Aug 2007 Location: Nr Reading Posts: 270 ![]() ![]() |
Sorry, my mistake then!
But are they worth it
Not to many 200km drives over corrugations where heat build-up is an issue on your daily commute then Ken?
I would say that 98% of the time no. However if you are doing stuff in the desert at high speed then yes. CarlS (my sons) standard 110 crew cab suffered from 'hot' shocks racing a Tomcat across the desert in Morocco. When he pulled up at the end of the day the car took about 10 minutes to stop moving.
Here is a couple of videos. Ferrying spectators to the 'special stage' The end of the 'special stage' 130's have feeling's as well you know ![]() |
Not many sand dunes in Berkshire though... so probably not for me
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
If you need a double-shock mount, you are doing something wrong.
Not been on the M40 recently then ![]() Naks your confusing NEED with WANT ![]() ![]() |
![]() My problem is that we don't the same choice in shock than you have in europe. So I'd like to fit twin-shocks in the case I need to change it and I don't want to wait 1 mounth. Could you explain why do you think it's a bad thing. Thanks |
It's not necessarily a bad thing if you just want it. ![]() If you need it, then it means you are overloading your Defender, unless you drive uber bad gravel roads on an everyday basis for long periods of time. |
