Home > Puma (Tdci) > Central locking keeps popping up |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 |
2008 Puma. When I blip to lock the locks drop but then pop open and set the alarm off after 3-4 seconds.
Anybody had this happen and if so what was the cause/solution? Thanks in advance. |
27th Jan 2014 5:04pm |
pjw4233 Member Since: 30 Nov 2009 Location: Lake District & Cheshire Posts: 273 |
Had something similar, and was due to a bad earth on the interior light.
27th Jan 2014 6:25pm |
PJW You're spot on! Just went out, switched off internal lights-locked no probs, switched tham back on again and same thing as before. Do you know where the bad earth was?
Thanks |
27th Jan 2014 6:35pm |
I never did find out as it cured itself. Only used to happen when it was really wet, i.e. after using a jet wash or heavy spray on the motorway. I pinned it down to interior light as it used to flicker when the central locking played up. Do you have a RAI as I've always suspected it may be where the RAI bracket screws in at the side of the windscreen as the wiring is underneath?
27th Jan 2014 7:56pm |
No. No RAI but the headlining has been down to fit cb aerial so thats a possibility. Will get everything checked over when I fit the Xdefend steering lock. In the meantime I've switched of the interior lights.
Thanks again. |
27th Jan 2014 9:28pm |
