Home > Puma (Tdci) > Central locking keeps popping up
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
2008 Puma. When I blip to lock the locks drop but then pop open and set the alarm off after 3-4 seconds.
Anybody had this happen and if so what was the cause/solution?
Thanks in advance.
Post #302618 27th Jan 2014 5:04pm
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Had something similar, and was due to a bad earth on the interior light.
Post #302644 27th Jan 2014 6:25pm
redhandluke
PJW You're spot on! Just went out, switched off internal lights-locked no probs, switched tham back on again and same thing as before. Do you know where the bad earth was?
Thanks
Post #302648 27th Jan 2014 6:35pm
pjw4233
I never did find out as it cured itself. Only used to happen when it was really wet, i.e. after using a jet wash or heavy spray on the motorway. I pinned it down to interior light as it used to flicker when the central locking played up. Do you have a RAI as I've always suspected it may be where the RAI bracket screws in at the side of the windscreen as the wiring is underneath?
Post #302697 27th Jan 2014 7:56pm
redhandluke
No. No RAI but the headlining has been down to fit cb aerial so thats a possibility. Will get everything checked over when I fit the Xdefend steering lock. Confused In the meantime I've switched of the interior lights.
Thanks again.
Post #302730 27th Jan 2014 9:28pm
