Home > Technical > TD5 Smoking |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Hi
Welcome to the forum. I do advise if you need to change the maf you fit VDO/SIEMENS, some of the cheaper ones can cause havoc with the car in many ways. The car should not be hesitant on reving up really, it may be good if you can get hold of a diagnostic tool or speak with the tuner who did it for you to have a look to see if something is out of place. it could be a million and one things causing the hesitant feeling and smoke including the tune its self a little strong for your cars setup. Do check all your hoses for splits and make sure all the clamps are tight. Pete |
24th Jan 2014 11:41pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
or a better solution is to take it to Pete and get it mapped properly! 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
25th Jan 2014 9:45am |
I would agree here 100% .. most cheap maf never give the right readings. ( I have had problems with td4 freelander ones . you quote for bosch one ,hour later owner rings up says I can get one a lot cheaper on bay explain about not reading right , normally still want cheap one ,they buy it ,we fit it , they come back week later , we fit bosch and its cost them more in the end |
25th Jan 2014 9:56am |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
Fit a Gen L/R MAF
It will work as it should Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
25th Jan 2014 8:17pm |
DanielSon Member Since: 24 Jan 2014 Location: Swansea Posts: 7 |
Thanks guys for the advice,, I certainly be changing the MAF .. and checking my hoses.. or is it worth fitting silicon performance hoses and new clips too?
The VDO/SIMENS MAF'S on ebay are about £70-90 is that about right for a genuine MAF ? someone told me that my cat could be blocked? or is that bad advice .. as I live in Swansea anyone know of a competent tuner that could take a look? as the guy who did it for me I felt was quite novice with a laptop and hadn't done many defenders |
26th Jan 2014 9:28pm |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
Sounds like a combination of problems, and possibly the ECU reverting to a default fuel ratio setting, and the smoke is possible appearing because of an incomplete / poor tune, or that the tuner only turned the fuel up (somehow).
A diagnostic is the first thing to do, as it could well give a simple answer. As said, the cheap MAF sensors are not worth a dime, nevermind the £30-40 they ask for. 1998 110 300Tdi White Hard Top |
26th Jan 2014 9:37pm |
with a diagnostic wold a normal mot type garage be able to do that ? or is it a specialist land rover tuners job? the guy who remapped it didn't have any diagnostic system.. im starting to think may be its a 50/50 problem with the MAF & the remap that's been put in..
once I buy a new proper MAF i'll start looking into having it looked at by a proper tuner cheers guys |
26th Jan 2014 11:21pm |
£70 -£90 is about right Get rid of the EGR Valve & the CAT. Check intercooler hoses for wear etc. You can fit better hoses & clips Better send your ECU to someone like Pete @ BAS for a proper job Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
27th Jan 2014 7:20pm |
that seems like a good plan cheers..
the mods ive done so far are egr removal k&n safari snorkle and a remap.. I will be buying the MAF this weekend..and next then I will buy silicon hoses, decat and straight through pipe.. and will most certainly be sending the ecu away so it can be done properly what about the intercooler ? can you clean it out or is it best just to buy a bigger alloy one ? |
27th Jan 2014 7:32pm |
Sorted ,, bought a new VDO MAF.. problem solved ,, no smoke and drives so smooth now.. now I fancy doing a few more mods..lol..
31st Jan 2014 8:38pm |
