Home > My Defender > DarthFender TD5 110
Page 5 of 16 <123 456 ... 141516>
Tiger
Installing Puma Seats in a TD5
Right so I've being doing this a while but here goes:
Here are my old Td5 seats, Techno cloth, yuk!!! Shocked
And since I have kids seats in the back I wanted better seats in the 110.
So I got a set of Puma seats, cubby & fixings Thumbs Up
Fronts are a straight swap so dead easy, the green string is a centre line running from the ash tray in the middle of the dash to the rear door handle to get a centre for the rear seats for fixing.
Once I'd got a centre I could offer the floor plate up and drill the six bolt holes
The floor plate bolts through the floor plan to large brackets that sit on the chassis rail (bought from Duckworths Thumbs Up )
These sit on top of the chassis rail and are bolted to the chassis via 3 bolts so you need to drill and tap a thread into the chassis.
The problem being that with tub in place you can't get these on top and over the rail Big Cry
So I had to cut the front off the bracket and, bolt it via 2 of the fixings and going to have to get it welded to the chassis for total safety. This makes the Puma seats a lot more secure, the TD5 seats and seatbelt anchors have no chassis fixings!! Shocked
Puma tubs are shallower to allow for the bigger seats this means in a TD5 you need to cut holes to make room for the seats to out came the jigsaw
Then in a true Heath Robinson fashion I made some high tech composite bodywork lowering device.
(Chinese takeaway box cut to size to make a mould and fibreglassed Rolling with laughter )
Paint to disguise
Getting there!
Next I needed to make some strengthening brackets for the seat fixings, they are too heavy to bolt straight to the Ali floor.
I bought some builders brackets from Wickes as I couldn't get the LR part.
Cut them down and drilled them
Test fit
Just another 3 to make now
Each one was bolted to the 1st to ensure they were the same
Painted
Next job is to re-trim the seats in Leather and fit them Thumbs Up
Post #302475 26th Jan 2014 10:59pm
mk1collector
Great write up Thumbs Up I'm thinking I might do this instead of exmoor high backs. Could you tell me the part numbers of the brackets you got from duckworths please and rough idea on cost?
Ray
Post #302481 26th Jan 2014 11:23pm
Tiger
Part number is AQR710290
£25 each
Post #302482 26th Jan 2014 11:31pm
mk1collector
Thumbs Up excellent cheers
Post #302485 26th Jan 2014 11:58pm
Is that re trim completely leather? KEEP CALM AND Drill ON
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #302492 27th Jan 2014 12:58am
Tiger
Nope, just normal XS stuff
Post #302502 27th Jan 2014 7:23am
Tiger
Started the retrim.
Puma seats are well made Shocked Took some doing in the end to do one seat Rolling Eyes
The base and back are held in with Hogrings which are a bitch to get to to bend open
Start fitting XS half leather.
1 seat done
Much better than the Grey Vinyl
Post #302771 28th Jan 2014 8:35am
Tiger
Updated List:
Done List
Install additional CAT2 Immobiliser - Done
Secret Squirrel Security Upgrade 1 - Done
Defender Windscreen Sticker - Done
Swap Alloys - Done
Leather Gear Gator - Done
Secret Squirrel Security Upgrade 2 - Done
New Chrome Caps for Wheel Nuts - Done
Mud Tray - Done
LED Interior Lights - Done
Upgrade Headlamp bulbs - Done
Clear Front & Side Indicators - Done
LED Side Lights - Done
Add BBUS Sounder - Done
Alloy Gear & Transfer Knobs - Done
Secret Squirrel Security Upgrade 3 - Done
X-Defend Steering Column - Done
Roof tag - Done
Modify key to one piece - Done
Fit Leather XS Steering wheel - Done
Fit better aerial - Done
Paint & Fit Roof rack - Done
Paint & Fit Ladder
Fit Air intake Cowl - Done
Fit Crystal Wipac Headlights - Done
Fit LED number plate light - Done
Fit LED reverse light - Done
Fit Headlamp Guards - Done
Fit Puma Interior Seats - Done
Fit Rear Speaker panels & Wire - Done
Fit new Front Bumper - Done
Paint Wing top Checker Plate - Done
Fit Mantec Swing away wheel carrier - Done
Fit Discovery Bike rack - Done
Immediate To Do (parts sat waiting)
Fit Tints to rear
Fit Lightbar
Fit LED Worklamp
Upgrade headlight loom
Fit SS Bolts
Fit side window demisters
Fix flappy door cards (&strip locks to stop bounce)
Fit MUD 12v Points in Front & Rear
Fit MUD curry hooks
Fit XS Leather Seats - 1 Seat done
Fit Heated Seats
Fit 'classic' LR SW Badge - Was done, fell off, need to rivet this time
Fit Soft 'A' bar
Fit Heated Screen
Fit Heated Mirrors
Finish Stereo upgrade (inc Amp, Sub and Speakers)
Fit Rock sliders
Future 'To Do' (don't have parts)
Window Guards
Dog Guard
Soundproofing
New Carpets
4 x X-Trouser
Rear step or NAS Rear Bumper
Repair rear heated screen - Done
Post #302777 28th Jan 2014 9:10am
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Looks great!
Great to see a list like any Defender should have. Constantly evolving and getting better with age and mods. Try and do that with a new vogue Cool
Keep it up Tiger (this line sounds bad) William
Post #302779 28th Jan 2014 9:36am
Tiger
It's just a case of finding the time to tinker.
Kids, work, life all need time aswell.
Post #302793 28th Jan 2014 11:06am
Tiger
Did a bit more work on the Install of the Puma Rear seats
The Chassis brackets are now fixed.
First job was to drill 8mm holes in the chassis rail in line with the seat retainer brackets fixing holes
The the holes then had to have a thread tapped so the brackets could be bolted with M8 high tensile bolts
Not easy to see from the photos but the bracket (new black metal bit) is now bolted (shiney silver bolt in view) directly to the chassis rail.
This means the Puma seats and therefore the seat belts are anchored to the Chassis rather than just through the thin ali floorpan like on the TD5 seats.
Took some doing but glad I'm trying to replicate the Puma rather than going the easy rout and just securing through the floor.
Post #305294 5th Feb 2014 1:53pm
Tiger
Last night I started to retrim the 60 Rear Seat
Tools needed
Ideally you could do with some hog ring pliers but I used needle nose and filed a small notch in the backs
Step 1 - Remove the plastic Trims (3 screws each side and one bolt. Biggest screw in the middle). The reclining handle pulls off and the trim takes some jaunty angle to remove it past the metal handle and mechanism.
You need to remove the bump stop (6mm allen)
Then the Fir Tree trip clips ( Every Defender owner should own a trim clip tool, they are ace and dead cheap)
Nice re-useable un-mangled Fir Trees
The Plastic / hardboard base will now slide off
You can now see all of the clips that hold the seat cover to the fusion and frame. Carefully undo these
Once all the clips are undone the cushion and cover will come away from the frame
The middle seat belt goes through the trim and needs to be undone first (Torx T50)
Base now fully removed
Right now the awkward bit, price open the hog rings at the rear corners.
Once undone you can peel the cover back from the edges to reveal the hog rings that hold the centre of the seat to a metal wire in the fusion foam.
Carefully prise open the 20 hog rings to release the cover from the fusion
I then straightened them as I didn't know the size prior to taking the cover off, the job would be easier with new rings as you could then just cut the old ones.
Here's the size for future reference
You can now start the re-trim
Place the cover over the fusion with the edges turned inwards
Working from the centre out re-fit the hog rings
Re-fit is the same in reverse, don't forget the centre seat belt Thumbs Up
Easy to do and a neat job
For those wondering why an Amp has appeared, I wanted to fit the amp somewhere discreet and the underside of the seat was perfect. Also while the seat was in pieces it gave me the chance to attach it to the frame of the seat not just the thin base.
Position
Mark & Drill
Rivnut into seat frame
Screw through base into 4 rivnuts using 4 SS Torx pan heads
Might do the back tonight if I get time Thumbs Up
Post #307385 12th Feb 2014 9:35am
Martin
Site Admin
What a superb write up, keep it coming Bow down Bow down  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #307415 12th Feb 2014 11:22am
Really informative - thanks for taking the time to photograph each stage and write it up Thumbs Up
Post #307446 12th Feb 2014 1:35pm
Tiger
Cheers Thumbs Up
I figured now that the 1st Pumas are coming up to 7 years old then a few might be doing this soon
Post #307482 12th Feb 2014 3:02pm
