![]() | Home > My Defender > DarthFender TD5 110 |
Great write up
![]() Cheers Ray |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Part number is AQR710290
£25 each |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20729 ![]() ![]() |
Is that re trim completely leather? WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Nope, just normal XS stuff
Started the retrim.
Puma seats are well made ![]() ![]() ![]() ![]() The base and back are held in with Hogrings which are a bitch to get to to bend open ![]() Start fitting XS half leather. ![]() 1 seat done Much better than the Grey Vinyl ![]() |
Updated List:
Done List Install additional CAT2 Immobiliser - Done Secret Squirrel Security Upgrade 1 - Done Defender Windscreen Sticker - Done Swap Alloys - Done Leather Gear Gator - Done Secret Squirrel Security Upgrade 2 - Done New Chrome Caps for Wheel Nuts - Done Mud Tray - Done LED Interior Lights - Done Upgrade Headlamp bulbs - Done Clear Front & Side Indicators - Done LED Side Lights - Done Add BBUS Sounder - Done Alloy Gear & Transfer Knobs - Done Secret Squirrel Security Upgrade 3 - Done X-Defend Steering Column - Done Roof tag - Done Modify key to one piece - Done Fit Leather XS Steering wheel - Done Fit better aerial - Done Paint & Fit Roof rack - Done Paint & Fit Ladder Fit Air intake Cowl - Done Fit Crystal Wipac Headlights - Done Fit LED number plate light - Done Fit LED reverse light - Done Fit Headlamp Guards - Done Fit Puma Interior Seats - Done Fit Rear Speaker panels & Wire - Done Fit new Front Bumper - Done Paint Wing top Checker Plate - Done Fit Mantec Swing away wheel carrier - Done Fit Discovery Bike rack - Done Immediate To Do (parts sat waiting) Fit Tints to rear Fit Lightbar Fit LED Worklamp Upgrade headlight loom Fit SS Bolts Fit side window demisters Fix flappy door cards (&strip locks to stop bounce) Fit MUD 12v Points in Front & Rear Fit MUD curry hooks Fit XS Leather Seats - 1 Seat done Fit Heated Seats Fit 'classic' LR SW Badge - Was done, fell off, need to rivet this time Fit Soft 'A' bar Fit Heated Screen Fit Heated Mirrors Finish Stereo upgrade (inc Amp, Sub and Speakers) Fit Rock sliders Future 'To Do' (don't have parts) Window Guards Dog Guard Soundproofing New Carpets 4 x X-Trouser Rear step or NAS Rear Bumper Repair rear heated screen - Done |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
Looks great!
Great to see a list like any Defender should have. Constantly evolving and getting better with age and mods. Try and do that with a new vogue ![]() Keep it up Tiger (this line sounds bad) William |
It's just a case of finding the time to tinker.
Kids, work, life all need time aswell. |
Did a bit more work on the Install of the Puma Rear seats
The Chassis brackets are now fixed. First job was to drill 8mm holes in the chassis rail in line with the seat retainer brackets fixing holes ![]() Click image to enlarge The the holes then had to have a thread tapped so the brackets could be bolted with M8 high tensile bolts ![]() Click image to enlarge Not easy to see from the photos but the bracket (new black metal bit) is now bolted (shiney silver bolt in view) directly to the chassis rail. This means the Puma seats and therefore the seat belts are anchored to the Chassis rather than just through the thin ali floorpan like on the TD5 seats. Took some doing but glad I'm trying to replicate the Puma rather than going the easy rout and just securing through the floor. |
Last night I started to retrim the 60 Rear Seat
![]() Tools needed ![]() Ideally you could do with some hog ring pliers but I used needle nose and filed a small notch in the backs Step 1 - Remove the plastic Trims (3 screws each side and one bolt. Biggest screw in the middle). The reclining handle pulls off and the trim takes some jaunty angle to remove it past the metal handle and mechanism. ![]() ![]() You need to remove the bump stop (6mm allen) ![]() Click image to enlarge Then the Fir Tree trip clips ( Every Defender owner should own a trim clip tool, they are ace and dead cheap) ![]() Nice re-useable un-mangled Fir Trees ![]() The Plastic / hardboard base will now slide off ![]() You can now see all of the clips that hold the seat cover to the fusion and frame. Carefully undo these ![]() ![]() ![]() ![]() Click image to enlarge Once all the clips are undone the cushion and cover will come away from the frame ![]() Click image to enlarge The middle seat belt goes through the trim and needs to be undone first (Torx T50) ![]() ![]() Base now fully removed ![]() Right now the awkward bit, price open the hog rings at the rear corners. ![]() Once undone you can peel the cover back from the edges to reveal the hog rings that hold the centre of the seat to a metal wire in the fusion foam. ![]() Carefully prise open the 20 hog rings to release the cover from the fusion ![]() ![]() I then straightened them as I didn't know the size prior to taking the cover off, the job would be easier with new rings as you could then just cut the old ones. ![]() Here's the size for future reference ![]() ![]() Click image to enlarge You can now start the re-trim Place the cover over the fusion with the edges turned inwards ![]() Working from the centre out re-fit the hog rings ![]() ![]() Re-fit is the same in reverse, don't forget the centre seat belt ![]() ![]() Click image to enlarge Easy to do and a neat job ![]() Click image to enlarge For those wondering why an Amp has appeared, I wanted to fit the amp somewhere discreet and the underside of the seat was perfect. Also while the seat was in pieces it gave me the chance to attach it to the frame of the seat not just the thin base. Position ![]() Mark & Drill ![]() Rivnut into seat frame ![]() Screw through base into 4 rivnuts using 4 SS Torx pan heads ![]() Might do the back tonight if I get time ![]() Last edited by Tiger on 12th Feb 2014 12:29pm. Edited 1 time in total |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
What a superb write up, keep it coming
Really informative - thanks for taking the time to photograph each stage and write it up
![]() I figured now that the 1st Pumas are coming up to 7 years old then a few might be doing this soon |
