Home > Puma (Tdci) > It all hinges on this |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Your driver and passenger doors are captive on the bulkhead but nut and bolt on the door. With the door fully open you can see the nuts in the inner edge of the door card. The rear passenger doors are not captive on the B pillar but the nuts are on a metal retainer. You can access them through a cut out behind the seat belts for the front seats. And again the nuts for the door bolts are in the inner edge of the door card.
I have developed a nack for removing hinges with out removing the door cqrd by slidong the. Nuts in the edge of the card. Good luck with re hanging the doors after ive re hung mine 3 rimes and im still not happy with em! |
24th Jan 2014 6:09pm |
Ignore my statemebt about rear doors I saw csw and assumed 110 lol
danridge Member Since: 28 May 2013 Location: Bath Posts: 438 |
This may help http://www.youtube.com/watch?v=ZM2ffHGXRq8
24th Jan 2014 6:14pm |
General Grabber Member Since: 27 Dec 2013 Location: Mos Eisley Posts: 49 |
Thanks very much. Shall investigate further tomorrow.
Any idea about the lower hinges on the rear door? Are the nuts captive on the body for that or not? Cheers. |
24th Jan 2014 6:18pm |
Good question ive avoided rear doors due to my failings with side doors lol
24th Jan 2014 6:23pm |
No, the rear door nuts aren't captive. They're hidden behind the plastic flap that protects the back of the lower lights and towing electrics connector. Darren
24th Jan 2014 6:33pm |
Thanks Darren,
Should keep me busy tomorrow. |
24th Jan 2014 6:43pm |
The plastic flap that coverts the bolts is a ! Razor sharp on your hands.... I've the wounds to prove it! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
24th Jan 2014 6:51pm |
OK cheers. Thanks for letting me know.
Anyone got any pics of this? |
24th Jan 2014 6:58pm |
Here you go. This is a 110 but it'll be very similar on a 90.
This shows the inside back of the wing with the plastic panel removed, which is held in by a single screw into the spire nut to the right of the large grey connector. That connector is for the towing electrics. You can just see one of the hinge bolts below the thick conduit centre right of the picture. Changing them is going to be a two person job unless you're an orangutan. Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
24th Jan 2014 7:29pm |
Thanks all,
Job now completed and all doors now have s/s pintorx security bolts fitted. Cheers. |
25th Jan 2014 4:21pm |
