Home > Technical > Swapping Transfer Box, how hard is it?
Page 2 of 2 <12
Dieselhead
Just been up and had a look at the D2
Sorry no diff lock Big Cry Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #301276 22nd Jan 2014 6:33pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Chris, it seem that in typical LR fashion it may have a diff lock, just no leaver to engage it! The only way to find out for sure is to crawl underneath, and check, this link provides some more info: http://www.discovery2.co.uk/diff_lock.html
Post #301385 22nd Jan 2014 11:17pm
dnorrishill
Bit more info on Ashcroft site as well: http://www.ashcroft-transmissions.co.uk/mi...-lock.html
Post #301396 22nd Jan 2014 11:49pm
The vast majority of Disco2s do not have the internals for the difflock fitted. These can be identified by the solid boss on the front output housing where the operating lever would be if there was one.
A relatively small number of very early Disco2s had the internals fitted but had no operating linkage fitted. These have the threaded spigot protruding from the front output housing (which can be operated with a spanner). These boxes are as rare as rocking horse poo and command a premium second hand.
An incredibly small number of Disco2s had everything fitted including the operating lever in the cab. These make RH poo look common place and I have never even seen one! For the last 10 years or so I've been trying to find the transfer gear lever assembly for one without success (anyone here have one I can buy?)
If however you are fitting a Disco2 non difflock box into a Defender it is very easy to fit the difflock from the Def box to the Disco box.
Post #301408 23rd Jan 2014 12:16am
Dieselhead
Look like I will have to go & have another look then Very Happy Its sitting on its bum as air suspension dropped & flat tyres. Good job I am slim!!
I did have a D2 before my current drive so know what to look for Cool
I just have to put an engine back in a corsa & then an L200 before I can do this Laughing Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #301621 23rd Jan 2014 9:19pm
Fish
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
My brother has a difflock on his disco 2. He had to fit the linkage from Ashcrofts. I think some of the very late run out facelift cars also have difflock as well.
Post #302821 28th Jan 2014 2:14pm
Yes, the last few did have the CDL internals (the operating linkage was an optional extra). It finally dawned on LR that TC was not an acceptable alternative to a CDL!
Anyone have a GENUINE transfer lever assembly for a Disco2 with CDL for sale? Been looking for one for ages!
Post #302851 28th Jan 2014 4:24pm
eddy
Australia
When removing the transfer bolts that hold it to the main box replace them with threaded rod[10mm?]Box can then be slid along the rods until it clears the splines.Makes it easier to replace with less chance of damaging oil seal.
Post #303096 29th Jan 2014 1:31pm
Page 2 of 2 <12
