Home > Technical > Swapping Transfer Box, how hard is it?
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I am planning to swap the transfer box on my TD5 90 to a Discovery 1.2 one, but I wanted a bit of advice on how hard it is to do?
I can hire an engine crane from HSS for about £30, but is it possible to do it myself on my drive?
Also are there any parts I would need to get, seals, bolts, etc.?
Post #299209 15th Jan 2014 10:50pm
Alex1976
It is just a big heavy lump to shift around, but technically not difficult.
I wouldn't bother with an engine crane - I used a transmission jack which was much better. I got my one on ebay for about £90 and its done two gearbox swaps now. Its like a small scissor type jack that goes from 100mm to 500mm wound up with a 1/2" drive socket.
For a straight swap you don't need any seals, but do put a ring of silicone sealant around the mating surface of the box where the drive shaft goes into the gear box.
I swapped to a 1.2 tbox that I got from Ashcrofts and it does make it cruise so much better.
Post #299213 15th Jan 2014 10:59pm
dnorrishill
Alex, thanks for the info.
There are a few transmission jacks on ebay like this: http://www.ebay.co.uk/itm/DRAPER-53095-FLO...29ff7e8c20
They seem to be rated at a max 150kg, is that enough for a transfer box?
Post #299221 15th Jan 2014 11:19pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I did mine about 6 months ago, best mod I've done so far, much nicer to drive in general, I don't do much towing so its great.
I was lucky because I have a local garage that I'm friendly with, they let me use their pit for the day and gave me a lift with the heavy lift, you ideally need a helping hand when taking the transfer box on and off, other than that it's fairly straight forward, as long as you get a bolt or nut back on the top you can stop sweating while trying to balance the weight. I'd recommend changing the seals at the same time, it only takes 5 mins to swap them over while you have things apart. Best of luck with it.
Post #299224 15th Jan 2014 11:33pm
Alex1976
Yep - thats exactly the jack that I used to do mine. It carried the weight of the tbox no problem. I would say the tbox weighs about 60Kg so well under the max weight of the jack.
Post #299231 15th Jan 2014 11:43pm
Depending on how strong you are, you might not need a jack. Or if you've got an able helper to give you a lift up & down with it, the rest is just nuts & bolts.
Post #299265 16th Jan 2014 8:21am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Post #299279 16th Jan 2014 9:44am
NickEJ
Slovenia 2004 Defender 90 Td5 XS CSW Galway Green
That's the best series of "how to" photos I've ever seen. Well done Nidge! Might do it myself now.
Post #299282 16th Jan 2014 10:13am
dnorrishill
Unfortunately I have neither the strength (sit at a desk 5 days a week) nor a willing helper at home!
Post #299326 16th Jan 2014 1:30pm
Good pictures in that thread above, however they seem to overdo things a bit....
as in, there's no need to remove the input gear from the back of the t/box. when you undo the t/box from the main box, the shaft just slides out on splines. same with re-fitting.
Taking the handbrake off is useful as it's quite a heavy bulky thing bolted to the transfer box, so good to get it out of the way.
Post #299386 16th Jan 2014 6:58pm
Dieselhead
If you get the bits Very Happy
Drive it over to my place & we will give you a hand to swap it over Thumbs Up
Couple of hours work me thinks Cool
A mate has a D2 which hes going to break up very soon. Why dont you buy the T box & just swap it over??? Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #299411 16th Jan 2014 8:46pm
dnorrishill
Seriously, wow if the D2 has a diff-lock you will be my new best friend!! Let me know, but that would be brilliant, thanks very much. Thumbs Up Very Happy
Post #299427 16th Jan 2014 9:39pm
Brucey
Poland 2004 Defender 110 Td5 DCPU Auto Java Black
I swapped my box (well the gears inside) by hand without lift or jack. In hindsight it was as mistake as I was short on time.
One thing to check which doused me a great deal of swearing Embarassed Embarassed If you are using a different gearbox or transfer box make sure that you have the locating dowels in place correctly before you try to lift it into place. I did not and found that I could not get the gearbox/transfer box to mate together Banging Head as I had two male dowels. It is easy to see now, but lying on your back trying to press the F**king thing into place with rust in your eyes it was not so easy Confused .
Bitter, me? never!
Chris Defender 110 DC converted Auto
BMW R1200GS
BMW F650GS Dakar
Post #299513 17th Jan 2014 9:17am
It isn't difficult to swap the difflock from the Defender box to the Disco box if the Disco box lacks the internals once both boxes are out.
Disco2 boxes with the difflock are not easy to find! Took me a long time to find one to donate the parts to retrofit the lock to my Disco.
Post #299526 17th Jan 2014 9:59am
Dieselhead
Ahh yes the diff lock
Not sure if the D2 has it. Its an auto which is cooked. I will find out next week & let you know Thumbs Up Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #299665 17th Jan 2014 5:43pm
