![]() | Home > Off Topic > Painting plastic.... what to use? |
D J,
Plastikote is very resilient against weather and moisture ingress and I have used it on window catches and lightguards on my Defender. It covers extremely well and with the primer you can apply a lot of coats in a very short time 10 minutes if I can recall between coats. Unaware how good it is against abrasions but would imagine a matt finish would not be the way to go. ![]() Treat every day as if it is your last....one day you will be right!! |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Cheers Mal
Is that aerosol or hand paint you used? |
In a can that goes 'psssssssst' when you press the button. Who are you calling an aerosol?
![]() I am naturally heavy handed and usually make a hash of spraying but with this stuff even I got a perfect finish as it dries before you can apply too much and it runs. The fact you can apply so many coats in such a short time also means you can build up the primer to mask any imperfections/repairs. You will obviosly need to 'key' the surface if it is currently smooth or the Plastikote can be removed like a sheet afterwards! ![]() Treat every day as if it is your last....one day you will be right!! |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Rather than painting....
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 ![]() ![]() ![]() |
Halfords do plastic paint in different colours in aerosol cans. Sticks and wears well.
B & Q also have a varied selection and stock Plastikote and other plastic coating paints too.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
I'd use acid etch for rigid plastics for it's etching properties into the plastic.
If it's anything with any flex in it at all then you need a plastic primer. So primer, base colour coat and then a clear protection coat. Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Cool, cheers all for the advice.
It's a Honda quad i've bought, for a bit of wheeler-dealering money making. The engine needs some TLC, but the rest is fairly sound. It's been on a farm all its life (well, several farms), so naturally all the lights have gone AWOL, although it was road legal at one point, so shouldn't be too hard ro re-instate it. I was in two minds whether to vinyl wrap the platic in realtree type stuff. A good friend of mine has a couple of quads in this and it looks good, although they were built like that... my effort would probably look like i'd actually hit a tree, so coating the bright red Honda finish is probably the way forward. |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
What would be the correct type of paint to use on the engine bay plastics as I would like to colour match these and the door mirrors.
