Home > Pictures & Video > Day out with Chunk and PDH without hitting a merc :D
Page 2 of 2 <12
TACK
Big Cry Big Cry Big Cry had similar story recently when I made a decision on the cheapest supplier of an item and then look at the bill and they did not tell me plus vat Evil or Very Mad a discussion followed Rolling Eyes
Looks the nuts, thanks for the prices Thumbs Up
Post #29975 16th Apr 2010 3:15pm
TallPaul
Ouch Shocked
Thanks for answer, can I ask which cage is it though?
Just wondering if its a bolt together or one that has to be welded, I know some of them have to be welded in place, others are all bolt on (like safety devices) and provided you are brave enough with a drill and your panels you can DIY fit!
Post #29976 16th Apr 2010 3:20pm
Cibit
Posted some pics in the gallery.
Specifically here is the rear drivers side set up
Outside
Inside
Underneath
And attached to the crossmember
And here you can just make out the new shape crosspiece to accomodate the puma bonnet
 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #29977 16th Apr 2010 3:27pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
What's that yellow wire/tube running up the side of the cage? Is that an extended breather? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #29990 17th Apr 2010 5:35am
K9F
Cibit wrote:
My bill for the work came to 500 more than the original quote said. The guy who did the quote has since left and he forgot to add up things like the roof meah and ladder etc.
I had a similar occurrence with TH Whites in Wootton Bassett with the fitting of my chequer plate some time ago. They misquoted! Fair play to 'em though they honoured the original quote and ended up fitting it at a loss. Needless to say they have received my custom since as a result! I thought legally companies have to abide by quotes even if it is they themselves that make a mistake once the work has been completed? I may be wrong though!
Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #29993 17th Apr 2010 7:56am
Page 2 of 2 <12
