![]() | Home > Pictures & Video > Day out with Chunk and PDH without hitting a merc :D |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
![]() ![]() ![]() ![]() ![]() Looks the nuts, thanks for the prices ![]() |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 ![]() ![]() ![]() |
Posted some pics in the gallery.
Specifically here is the rear drivers side set up Outside ![]() Click image to enlarge Inside ![]() Click image to enlarge Underneath ![]() Click image to enlarge And attached to the crossmember ![]() Click image to enlarge And here you can just make out the new shape crosspiece to accomodate the puma bonnet ![]() Click image to enlarge 59 2.4 110 XS Utility 55 TD5 110 CSW Special Vehicle |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
What's that yellow wire/tube running up the side of the cage? Is that an extended breather? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
I had a similar occurrence with TH Whites in Wootton Bassett with the fitting of my chequer plate some time ago. They misquoted! Fair play to 'em though they honoured the original quote and ended up fitting it at a loss. Needless to say they have received my custom since as a result! I thought legally companies have to abide by quotes even if it is they themselves that make a mistake once the work has been completed? I may be wrong though! ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
