Home > Technical > minimum pressure on tire needed |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5666 |
I've driven mine with 10psi in them, so i know that is ok in mine, but I am on BFG km2's. What tyres are you running?
Andy |
17th Jan 2014 9:07am |
yeldef Member Since: 06 Feb 2013 Location: belgium Posts: 26 |
thx for the answer , 10 PSI .. that's lower than i thought, you run 31 PSI standaard ?
How much did the car lower ten ? Tires are Bf goodrich All terrain 265/75/R16 BFG for a defender 110 DCPU |
17th Jan 2014 9:20am |
Yes I run 32 as standard all round. Don't know how much it lowered it, I was doing for traction, not height, so payed no attention to that. The tyres don't deform at all until under 18psi.
Andy |
17th Jan 2014 9:33am |
Ragerover Member Since: 26 Dec 2013 Location: In a land far far away Posts: 145 |
You could also use 4 big ratchet straps to pull suspension down
It's only temporary and it'll stop it rocking so much in container |
17th Jan 2014 9:45am |
can you still ride with the ratchet on ? It just from the parking lot into the train.
just connect the top of the spring with the lowerbottom of the spring ? If so that's maybe a solution for parking my car in cityparkings... |
17th Jan 2014 10:03am |
