Home > Technical > puma diff noise
Page 1 of 3 123>
Tim seymour
Australia
puma diff noise
hi my name is tim i have a 2007 model defender which i am having a fair bit of trouble with the rear diff noise. iam on my 4th and this is no better if not worse. ihave been told that the diff may need more peload.and can anyone tell me if landrover are just replaceing the diff and not allowed to adjust the peload by the dealers Tim hope someone can help Sad Big Cry
Post #29466 10th Apr 2010 11:30pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Four Diffs and the noise is the same what are the chances of that, I'd be looking elsewhere Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29470 11th Apr 2010 7:36am
Tim seymour
Australia
thankyou the noise is still there but is abit diffrent if you know what i mean each time thay change the diff the dealers have had ear phones on the diff for a recording which was sent back landrover Crying or Very sad cheers
Post #29472 11th Apr 2010 8:00am
willy eckerslike
Hope you get it sorted Tim, seems quite a few of the 2007 models had diff problems. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29473 11th Apr 2010 8:20am
mse
What is the noise i think certain types of whine type noise is normal as they all seem to do it. Mike
Post #29482 11th Apr 2010 9:19am
Tim seymour
Australia
thankyou the whin is quite loud comes in at just under 80km to110km it will drop out on the float but comes back again when you put the foot down.the last one was the reverse when you took your foot off thankyou tim Sad
Post #29486 11th Apr 2010 9:59am
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Yeah same here, fairly loud whine when backing off from 120kph down to 70kph on motorway. I'm told "they all do it", just feel that mine is somewhat excessive.
Post #29535 11th Apr 2010 8:36pm
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Tim, I bought a TD5 new in 2001 and experienced what I thought was a rear diff whine at at around 100 - 110kph.
The dealer said it wasn't the diff but the transfer gears. I didn't believe him, but he changed the gears and the noise went away. Just a thought.
Austen. Rover 12 1935
Rover 20 1940
Rover 100 1960
Defender TDC1 2008
FL2 TD4 2008
Post #29547 12th Apr 2010 12:00am
Tim seymour
Australia
yes thankyou for all the replys. the noise or whin changes when thay change the diff so it make you think it would be the diff. on the outher hand why would landrover want to change the diff 5 times if is is a normal noise.it is embarrassing when a mate askes what the hell is that noise coming from a 50000 thousand dollar landrover thankyou again ps sorry i couldnt back earlyer i been working away Question Shocked
Post #29937 16th Apr 2010 8:29am
K9F
Tim,
One would assume that the diffs removed from your vehicle would possibly have been subjected to further investigative action. I would enquire if that is the case what was found i.e. was there any excessive signs of wear/stress etc.
If not ask the dealers to have a closer look at the next one or one of the ones that have been removed previously. Either way it should either reveal you have a serious problem or lay your mind to rest as nothing physical was evident. Good luck!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #29940 16th Apr 2010 9:06am
Tim seymour
Australia
thankyou i will certainly ask the qustion buy the way there must be a lot people out there with my problem dose your 90 make whin thankyou .ps i would like to here from anyone with the same problem and what landrover has done to fix it cheers Smile Very Happy
Post #29947 16th Apr 2010 9:51am
K9F
Tim,
I have a 2008 90XS and I have been fortunate enough not to have suffered any differential problems to-date. I do however sympathise with your plight. I am surprised that to date Land Rover have been prepared to continually throw diff after diff at your vehicle in the vain hope it will sort itself out. If I were you I would be 'as insistent as one could be' taking the history of your vehicle into account and insist on further more-detailed investigation and a replacement vehicle until such time as yours is sorted. They'll soon get to the root cause if you create a little commotion especially within earshot of other potential customers.
Good luck! Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #29949 16th Apr 2010 10:05am
Tim seymour
Australia
thanks again i will take all the advice back to landrover and will let you all you good people know the out come in weeks to come Razz
Post #29955 16th Apr 2010 1:02pm
mse
I some times wonder (and caught our last dealer out) whether they do make any changes at all!
I cant believe (and know that they arent) that multiple new replacements are approved and complete.
I took to marking in several places, the items to be changed - after a couple of times they started to replace items (BTW it was using paint markers LR use to mark parts at production so they couldnt scratch it off!)
Its a sad world. Mike
Post #29994 17th Apr 2010 9:54am
heinrichnel
Namibia 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi,
I have a 2008 110 with the same issues. Had a whining noise coming from the rear, Stealers said it was the transfer box and replaced it at 19000km. Noise did not disappear, then they order a new diff, had to be shipped all the way from England, don't carry it in stock in South Africa???? Replaced the rear diff, which I did thought was the issue, now much better, still a slight wine deceleration from 120 to 100, but much better!
So my question, good idee to fit an ARB locker in the rear? Should also solve the problem, as far as I am aware it is a better quality 3rd member than the LR one, why I am considering this is my factory warranty expires in couple of months and I don't have the money to keep on replacing the diff every year!
Heinrich
Post #30004 17th Apr 2010 2:52pm
Page 1 of 3 123>
