Home > Td5 > 2002 TD5 90 FUEL PUMP ACCESS HATCH
Razler
United Kingdom 2002 Defender 90 Td5 HT Zambezi Silver
Can anyone point me in the correct direction... I have been looking for the measurement for cutting a access hole above the fuel pump on my 90 TD5, after a google search found the info on landyzone.. But after more opinions! I have drawn out a rectangle but surly a cyrcle would be better with a plastic hatch way bonded in?
Help appreciated!
Post #299315 16th Jan 2014 12:04pm
ibexman
Iwould cut a square hole easier with a small grinder use some rivnuts and screw an access panel on Thumbs Up
dont forget the tank is really close
Post #299317 16th Jan 2014 12:10pm
Razler
Sounds like a good idea but holes are stronger due to less material being removed? Any measurements anyone?
Post #299336 16th Jan 2014 12:43pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
have a look at my thread as i have just done exactly this!!!!
http://www.defender2.net/forum/topic25959.html 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #299347 16th Jan 2014 1:51pm
I got hold of an old ex disco fuel pump access cover. it's round (with a slight flat on it making an "edge")
Got it from a scrapyard for nothing. think it's held in with 6 screws; I marked it out on top of my pump, cut the holes, and drilled the screw holes then filed them out square and used the plastic nut-serts which are tapped in. then I could use self tappers to remove it as often as I needed.
A Td5 pump will fit through the disco cover too.
I'll try and find some pics I took.
Post #299387 16th Jan 2014 6:02pm
