Home > Td5 > 2002 TD5 90 FUEL PUMP ACCESS HATCH |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Iwould cut a square hole easier with a small grinder use some rivnuts and screw an access panel on
dont forget the tank is really close |
16th Jan 2014 12:10pm |
Razler Member Since: 16 Nov 2013 Location: NORTHUMBERLAND Posts: 50 |
Sounds like a good idea but holes are stronger due to less material being removed? Any measurements anyone?
16th Jan 2014 12:43pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
have a look at my thread as i have just done exactly this!!!!
http://www.defender2.net/forum/topic25959.html 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
16th Jan 2014 1:51pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
I got hold of an old ex disco fuel pump access cover. it's round (with a slight flat on it making an "edge")
Got it from a scrapyard for nothing. think it's held in with 6 screws; I marked it out on top of my pump, cut the holes, and drilled the screw holes then filed them out square and used the plastic nut-serts which are tapped in. then I could use self tappers to remove it as often as I needed. A Td5 pump will fit through the disco cover too. I'll try and find some pics I took. |
16th Jan 2014 6:02pm |
